- Hardware & Machines
- Computers and OS's
- ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
24 Feb 2024 12:34 #294207
by wez
Replied by wez on topic ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Thanks Mecanix. Yeah I'm all over the P4 Thanks for the heads up though! Its certainly going to be interesting to see how they perform and any quirks.
I intend on having firmware releases for ESP32 SPI & RMII Ethernet, S2 USB, S3 USB and P4 USB & Ethernet (since it has once again). The P4 won't have ESP-NOW low latency wireless though which I believe people may like to adopt once they see how useful it can be.
cornholio,
Yes that is a feature that will be added soon. I've chosen a design path to ensure PCNT counter peripheral is available for full use so high speed encoders etc can be implemented. It's an issue in my github repo.
I'm also aware of the hesitancy towards USB for EMI on CNC machines however it's still a diff pair like Ethernet, shielded USB cables (so many crap ones) and ferrites should ensure no issues. The USB PHY on the S2/S3 is very robust I've found so at least based on what I know and experienced I doubt it would be an issue for most use-cases
cornholio,
The following user(s) said Thank You: aparecido
24 Feb 2024 13:37 #294209
by Mecanix
Replied by Mecanix on topic ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Are you bare metal techdoc programming this or using the idf SDK apis?
Also looking forward this P4 hardware. If you plan on making use of the hardware counter this is where the P4 will shine. E.g. the existing S3 won't multi channel the hw counter, to my limited knowledge mind you.
Are you working from a repo? Can we spy on your progress?
24 Feb 2024 19:38 - 24 Feb 2024 19:41 #294238
by wez
Goal was to create a project that almost anyone can develop or contribute to and keep it open.
As that is a core requirement and for development speed I decided to use the Arduino frameworks.
Plenty of bare metal programming experience and as well as using idf SDK but that would cause headaches for some and I know LinuxCNC is full of tinkerers!
Arduino framework has certainly presented some challenges too but knowing that it's possible to rapidly develop something that is reliable, performs and is multi-platform in two-three weeks as a single contributor - it pretty much had to be Arduino.
It's somewhat rough round the edges so far, developed very iteratively but it does work. There's a few bugs that I have recently fixed and will be pushed soon.
Prefer to work in smaller increments but I have limited time and many distractions at the moment so it's easier to release in a more offline sprint style, at least for now.
Overall presentation, setup guides, contribution docs and setup will be updated in time.
Ultimately it's board agnostic firmware and configurable at runtime.
Initial USB release for S2 is coming soon. S3 is WIP.
USB requires Arduino as a component in IDF for the custom USB Net driver. Will likely port ESP32 over to that too to allow for sdkconfig specific optimisations to LWIP for lower latencies.
There are plenty of improvements that can and should be done longer term to maximise available resources for any future features, as usual.
github.com/wezhunter/ESP32_LinuxCNC_MotionController_RealTime
Last edit: 24 Feb 2024 19:41 by wez.
24 Feb 2024 21:24 #294257
by Mecanix
Interesting. I had a whole different vision for linuxcnc, and it doesn't include 'thinkers' and other bugineers (no offence to the makers). I was under the impression (hopeful?) that you were planning to maintain a professionally engineered solution of which exploits the core capabilities of espressif's. This unfortunately involves bare metal... just can't see it happening using the thick APIs tbh. Unless ofc you are trying to re-do what many already did...
Arduino; aw come on now man. I'm already having a hard time picturing folks running their several thousand dollar worth machine-tools on some crappy random linuxboxes and all sort of fpgas, please don't make it worst. The espressif Arduino SDK is for flashing LEDs and driving buttons...
An attribute that stands out worlds better than any other I've seen so far is... your attitude. Skills also, judging from the code base I've quickly seen on your g'hub. On the positive side! Be you I'd own the project entirely and toss out the whatever tinkers out of it..... ..... .... And engineer a LINUXCNC proper package, which is what the community needs. (my 2c)
The following user(s) said Thank You: wez
24 Feb 2024 21:35 - 24 Feb 2024 21:43 #294261
by wez
I hear you completely and thanks for the kind words.
Nothing says I'm not going to be moving over to idf only at some point in the future, if required. Dev of this has been about speed to prove it's possible.
Arduino libs can be fine just as long as you know them intimately and all their edge cases which takes experience. They get a bad rap, for justified reasons.
I know once I've done with optimisations and have a controlled build environment I think you'll be surprised.
Take a look at the Tasmota project - based on Arduino. I've 30 of them dotted around and they are absolutely rock solid. Yes use-case matters but I've completed low latency work for other critical applications (that I can't share) and performs excellently (even compared to a raw IDF project) - key part is knowing the libs, being very very selective and optimise. It saves a lot of time and effort.
EDIT: mixing IDF and Arduino is the key part. Arduino framework can run as a native IDF component which gives the best of all options. Bare metal access, IDF optimisations, selected Arduino libs. Ease of codebase management
Last edit: 24 Feb 2024 21:43 by wez.
24 Feb 2024 22:06 #294268
by Mecanix
Not that I have much experience with the SDKs myself, and so take what I say with a grain. All I know for certain is the applications that I had to rig for myself (and/or few commercial) all required the tech doc and lowlevel for timings to 'sort of' checkout. Let alone half-data-integrity using those closed source ICs. No f'kin way I've ever managed to accomplish half-precision using those thick layers. By any means call me a noob, or maybe me oscope's gone bad or need calibration, dunno...
Regardless. You took it to the next level from what I've seen. Respect for that. Subscribed!
24 Feb 2024 22:25 - 24 Feb 2024 22:26 #294270
by wez
Yeah your absolutely right, it's just that things really have evolved so much over the years which I've been fortunate enough to have been able to stay up-to-date with intimately.
Really can mix everything together now but approach and execution is what's crucial.
Just as an example, take a look at FastAccellStepper library - uses RMT peripheral registers directly but it's wrapped in a nice Arduino lib but uses IDF.
It performs very very well. Can likely be improved further to eek out higher pps than 200khz total via RMT. Which may explore in future if it's actually required...
Using Arduino frameworks to take care of the non-time-critical aspects such as config, setup, webui and logging and go deep on the raw time critical components such as motion, IO interrupts and networking/USB. All of those can be drivers or components as a modular architecture within the build system.
Firmware flash sizes can be reduced by removing lots of unnessecary components.
Designing a solution that's both feature rich and reliable would take a very very long time otherwise (10x at least). If used pure IDF then the codebase becomes an abstract nightmare for future maintainers and also requires specific skillsets, sure, little knowledge is dangerous but if rationale is documented in code properly then helps mitigate that risk somewhat.
Longer term, reliable, well documented is important.
Once it's at a state where people see it running on a machine with torture tests and the full feature-set then I think it'll convince you
I will be designing and selling professional EMI complaint boards in the future.
Can't do everything for free.
I've developed a UHF RFID (EPC GEN2) solution using ESP32-S3 via some proprietary asics and RF frontends and so forth so EMI isn't going to be an issue!
Rick Hartley is a board design legend and recommend his lectures to anyone
Last edit: 24 Feb 2024 22:26 by wez.
24 Feb 2024 22:41 #294272
by Mecanix
I'm already convinced, don't get me wrong. Seen it running and scoped at 40'ish khertzies on your vid. Blew my mind half in fact (a ten bucks IC, imagine). Also fully aware you are at the proof of concept phase and seeking advice on how to take it to the next level - a low cost, widely available and effective solution that is.
Knowing all that I can't help but to stick to what I've advised already; leave the thinkers aside. They'll slow both you and the project all together. Don't ask how I know...
"Optimization" Love that word!! Sounds so good, not sure why.
24 Feb 2024 22:48 #294274
by wez
Haha 10 bucks IC. Nah, you know your stuff!
Thanks for the advice, understood and taken on board
Yeah it's a nice catch all for "figure it out later"
24 Feb 2024 22:53 #294275
by pippin88
Replied by pippin88 on topic ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Very interesting work.
I think what is needed is more complete board options, like Mesa. So an ESP32 based board with protected 24v GPIO etc would be great.
Something that a relative novice can deal with, without having to design or build their own PCB. Parallel port is harder and harder to get, and I think step generation hardware is the way to go anyway.
I can do some basic PCB stuff, but time wise it's not worth it for one machine. I have some machines, like a lathe, I don't really want to spend $300 for mesa cards (shipping to Australia from US is expensive) and something cheaper would be great.
Time to create page: 0.400 seconds
