How to reset 5221, 5222 and 5223 parameters (G54)?
30 Dec 2017 18:34 #103867
by nicokid
Thanks and happy new year
Nicola.
Replied by nicokid on topic How to reset 5221, 5222 and 5223 parameters (G54)?
OK, but I still do not understand what the difference is between L2 and L20. However it does not matter, I use L20 and I think it does its job.No, The X must have a number after it.
For example using this command to touch off the right side of the piece.
You would type G10L2P1X0, if you wanted that point to be 0 in your G54 work coordinate system.
If you were locating off a hole 1" from where you want the edge to be you could enter G10L2P1X1.
Nicola.
- Thank you received: 1370
31 Dec 2017 03:22 - 31 Dec 2017 03:28 #103888
Replied by Todd Zuercher on topic How to reset 5221, 5222 and 5223 parameters (G54)?
Let's say that your machine is located at the machine coordinate position (G53) X5.32 Y3.45 Z-2.34 and the G54 system is active. Issuing G10L20P1X0Y0Z0 will make the DRO show X0 Y0 Z0 at that point. Issuing G10L2P1X0Y0Z0 will make the DRO show X5.32 Y3.45 Z-2.34 .
Last edit: 31 Dec 2017 03:28 by Todd Zuercher.
The following user(s) said Thank You: nicokid
02 Jan 2018 22:10 #103967
by nicokid
Many thanks and happy new year.
Interesting. I still have to understand how DRO works without encoders but this is another matter.Let's say that your machine is located at the machine coordinate position (G53) X5.32 Y3.45 Z-2.34 and the G54 system is active. Issuing G10L20P1X0Y0Z0 will make the DRO show X0 Y0 Z0 at that point. Issuing G10L2P1X0Y0Z0 will make the DRO show X5.32 Y3.45 Z-2.34 .
03 Jan 2018 00:32 #103971
The DRO works pretty much the same without encoders as they do with, so long as the stepmotors don't loose position.
