Passing argument from user defined m code to python script
22 Aug 2019 18:54 #142875
by mmt
Passing argument from user defined m code to python script was created by mmt
I'm sure this has been covered but I can't get it to work.
I am trying to pass a variable from M101 Pxxxx to a python script.
In the python file I am just writing the variable to a file for testing.
I put a pin state change in the M101 just to visually see that it is working with HAL meter.
Here are my 2 files. The M code file works fine and the python file work fine it just wont pass the parameter.
M101
#!/bin/bash
python /home/kent/linuxcnc/m_codes/current_command.py $1
halcmd setp parport.0.pin-17-out True
exit 0
current_command.py
requested_current = $1
set_current = requested_current
f = open("/home/kent/linuxcnc/write_test.txt", "a")
f.write(set_current)
f.close()
Thanks in advance
Attachment not found
M101
#!/bin/bash
exit 0
current_command.py
f.close()
Thanks in advance
- Thank you received: 1370
22 Aug 2019 20:30 #142878
Replied by Todd Zuercher on topic Passing argument from user defined m code to python script
I think the problem is in your python script, and how you are trying to pass the argument to it.
www.tutorialspoint.com/python/python_command_line_arguments.htm
22 Aug 2019 22:02 #142880
Replied by andypugh on topic Passing argument from user defined m code to python script
Your M101 can be a Python script, no need to go via bash.
Then (as has been said) you get the P and Q with sys.argv.
One reason to use a bash script calling a oython script is if you want the pythin to run in the background, as explained here:
forum.linuxcnc.org/10-advanced-configura...cript?start=10#57807
If you need to pass more than 2 parameters then you can use a Python remap instead. (ie remap an unallocated M or G-code outside the M101 to M199 range, bt that is a little more work)
- billskeen63
10 May 2021 14:11 #208480
by billskeen63
Replied by billskeen63 on topic Passing argument from user defined m code to python script
Did you ever get this to work?
Bill
Bill
10 May 2021 17:22 - 10 May 2021 17:24 #208490
Yes, I just tried it.
Save this file in the same folder as the INI of your config as "M110"
Make the file executable
check that is works at the command line first:
If that works, then start LinuxCNC and in the MDI window run:
And you should see the P and Q numbers.
#! /usr/bin/env python
import sys
import tkMessageBox
print sys.argv
P, Q = float(sys.argv[1]), float(sys.argv[2])
tkMessageBox.showinfo(title="M110", message="P was %d and Q was %d"%(P, Q))
chmod +x M110
./M110 12 44
M110 P100 Q231
Last edit: 10 May 2021 17:24 by andypugh.
The following user(s) said Thank You: wasausky
