User defined M-code calling python script
- Thank you received: 4968
14 Apr 2015 20:38 #57799
I can't see why that would be. Can you see if LinuxCNC is sending a "terminate" signal?
Replied by andypugh on topic User defined M-code calling python script
when I click back to my axis screen it closes the camera window.
- dienno
14 Apr 2015 20:48 #57800
by dienno
Replied by dienno on topic User defined M-code calling python script
How can I check if linuxcnc is sending a terminate signal?
14 Apr 2015 20:51 #57801
Do you have a signal handler in the Python code?
- dienno
14 Apr 2015 20:55 #57802
by dienno
You are getting way outside of my skill level now. Sorry. Unfortunately I'm a mechanical engineer.
I'm pretty sure that I don't have a signal handler in the Python code.
I posted the python script call M102 in one of my last posts.
I am at work now so I can't try the spawning process either, but it sounds like that might be a solution that circumvents the terminating issue.
14 Apr 2015 20:58 #57803
Mine too (So am I)
Mine too (So am I)
- dgarrett
- Thank you received: 325
14 Apr 2015 21:54 #57804
by dgarrett
Replied by dgarrett on topic User defined M-code calling python script
An example session showing an M file calling a python/tkinter file.
$ # Start in the directory for the axis sim:
$ cd configs/sim/axis
$ # Copy axis.ini:
$ cp axis.ini tst.ini
# Edit tst.ini for explicit specification for M file location:
$ gedit tst.ini
# Show explicit specification for M file location:
$ grep -2 USER_M_PATH tst.ini
[RS274NGC]
USER_M_PATH = .
$ # Show the M102 file:
$ cat ./M102
#!/bin/bash
echo "this is $0"
./a.py &
echo "started a.py in background"
exit 0
$ # Show the python file (a.py):
$ cat ./a.py
#!/usr/bin/python
def bcmd():
print 'hellooooooooo'
import Tkinter
rw = Tkinter.Tk()
b = Tkinter.Button(rw,text="Hello",command=bcmd)
b.pack()
rw.mainloop()
$ # make sure both files are executable:
$ chmod +x ./M102
$ chmod +x ./a.py
$ # test simulator tst.ini
$ linuxcnc ./tst.ini &
F1,F2, Home All, MDI tab, Run M102:
this is ./M102
Push the Hello button
hellooooooooo
- ArcEye
- Thank you received: 758
14 Apr 2015 22:02 #57805
by ArcEye
Replied by ArcEye on topic User defined M-code calling python script
The reason is covered in passing in the docs
www.linuxcnc.org/docs/devel/html/gcode/m...tml#sec:M100-to-M199
Basically it is the difference between serial and parallel.
If Linuxcnc executes a script it waits for a return value before it continues, otherwise havoc would ensue as the machine continued moving, before whatever was commanded has taken effect.
To execute as a standalone app, you need to use the & suffix in bash or use whatever spawnlpe() equivilent there is in python so that return value goes back to Linuxcnc
When the script is executed the PATH env variable will be used (as modified by /scripts/rip-environment if a RIP) so the executable needs to be in a known location.
You might get away with having it in the same dir as the M1xx script, don't know if I have tried it, I normally just symlink into /usr/local/bin for anything outside the env I want to be able to execute
14 Apr 2015 22:04 #57806
Are you saying that it is necessary for the M102 to call bash file which calls the Python file, rather than call the Python file directly?
Is that because the M102 file has to return 0 and exit?
- dgarrett
14 Apr 2015 22:20 - 14 Apr 2015 22:36 #57807
by dgarrett
When an Mnnn file is invoked, it must exit in order for LinuxCNC to continue running a gcode program.
So to start an application using an Mnnn file and keep it running,
it is convenient to use a helper Mnnn script that can start the application in the background
and then exit.
If the Mnnn program exits with return code 0, an including gcode program will continue.
If the Mnnn program exits with return code not zero, an including gcode program will stop.
The helper Mnnn script can be in any form of executable so long as it is found by
the search rules for Mnnn files. An application started by a Mnnn helper script will be found
using the PATH environment unless an explicit path is used. In the example above, a.py
resides in the directory of the configuration file and it was started with an explicit pathname (./a.py)
Recent LinuxCNC versions support an ini file stanza to start independent, persistent applications:
[APPLICATIONS]
APP=appname
ref: www.linuxcnc.org/docs/2.7/html/config/in...APPLICATIONS-section
and then exit.
[APPLICATIONS]
APP=appname
Last edit: 14 Apr 2015 22:36 by dgarrett.
- dienno
15 Apr 2015 09:12 #57810
by dienno
ok, I went back to the set up where I have an mcode (M100) which is a bash script that changes the camera piston state and calls the python script.
It turns out that the reason it was not launching the python script was because I needed an absolute path to the python file ( I guess it could also be relative if I new where it was searching from but this seemed easier. The & in the code to try spawning did not work.
Either way it works and functions how I would like it to.
Here is the final code that I used
Custom mcode bash script (File name M100)
and the python script that runs the output from the live camera.
Thanks again
#!/bin/bash
# file to engage camera piston
halcmd setp parport.1.pin-17-out False
~/linuxcnc/configs/DVDCNC1/mcodes/camera1.py
exit 0
#!/usr/bin/python
requires: python-opencv
import cv2
#required for rotation transform
import numpy as np
camera_number = 0 #0, 1, x..
white = 255,255,255
black = 0,0,0
red = 0,0,255
green = 0,255,0
blue = 255,0,0
#constants
rot_angle = 90 #Angle to rotate image by
color_line = blue #lines and circles color
scale = 1
x_offset=0 #offset between camera and spindle
y_offset=20 #offset between camera and spindle
#captures video from 0
cap = cv2.VideoCapture(camera_number)
ret, frame = cap.read() #capture the first frame to determine size
img1 = frame #rename frame before transformations
# find the orginal height and width of the image (output is a tuple)
rows, cols, depth = img1.shape
#print rows, cols, depth
# Get rotation matrix getRotationmatrix2D(center,angle,scale)
M = cv2.getRotationMatrix2D((cols/2,rows/2),rot_angle,scale)
while(True):
# Capture frame-by-frame
#ret = cap.set(3,640)
#ret = cap.set(4,480)
# calculate rotated image warpAffine(input image,output image,trans matrix,output size)
img_rotated = cv2.warpAffine(frame,M,(cols,rows))
# add lines and circles to the captured frame
cv2.line(img_rotated,(0,(240-y_offset)),(640,(240-y_offset)),(color_line),1)
cv2.line(img_rotated,((320+x_offset),0),((320+x_offset),480),(color_line),1)
cv2.circle(img_rotated,((320+x_offset),(240-y_offset)), 20, (color_line), 1)
cv2.circle(img_rotated,((320+x_offset),(240-y_offset)), 50, (color_line), 1)
cv2.circle(img_rotated,((320+x_offset),(240-y_offset)), 90, (color_line), 1)
cv2.circle(img_rotated,((320+x_offset),(240-y_offset)), 130, (color_line), 1)
cv2.circle(img_rotated,((320+x_offset),(240-y_offset)), 170, (color_line), 1)
cv2.rectangle(img_rotated,(0,450),(80,480),(0,0,0),-1)
font = cv2.FONT_HERSHEY_SIMPLEX
cv2.putText(img_rotated,'[q]uit',(10,470), font, 0.7,(255,255,255),1)
#cv2.putText(img_rotated,'[q]uit [a]circle+ [z]circle- [c]olor',(10,470), font, 0.7,(255,255,255),1)
# shows final image imshow(window_name,target_image)
cv2.imshow('DVD CNC Camera', img_rotated)
# wait for input keys
if cv2.waitKey(1) & 0xFF == ord('q'):
break
# When everything done, release the capture
cap.release()
cv2.destroyAllWindows()
Thanks again
Time to create page: 0.066 seconds
