Unexpected Results - Wasteboard
- Jeff_in_Wa
- Thank you received: 5
21 May 2021 01:50 #209719
by Jeff_in_Wa
Unexpected Results - Wasteboard was created by Jeff_in_Wa
I'm not sure this is the right place for what I'm experiencing. But I've been trying to get a new wasteboard hole pattern done and the results are a mess.
Using Fusion, I'm using the EMC post for Linuxcnc.
I have zeroed out the dimensions and heights in the tool file
One of the problems I'm having is when the tool bores out a hole, it drags out of the hole on it's way to the next hole. Yet, I've got a 5mm height for rapids.
The other issue is each row is fairly accurate in distance between holes. But when the tool moves to the next row, the row is skewed as it moves across the board.
All along I've been thinking I have a machine problem/.ini settings etc. I began to wonder if the header in the gcode post is not right for linuxcnc.
Here is the top part of the latest post I was trying to run...
(SPOILBOARD HOLES)
N10 G90 G94 G17 G91.1
N15 G21
(WHEN USING FUSION 360 FOR PERSONAL USE, THE FEEDRATE OF)
(RAPID MOVES IS REDUCED TO MATCH THE FEEDRATE OF CUTTING)
(MOVES, WHICH CAN INCREASE MACHINING TIME. UNRESTRICTED RAPID)
(MOVES ARE AVAILABLE WITH A FUSION 360 SUBSCRIPTION.)
(BORE1)
N20 T4 M6
N25 S12000 M3
N30 G54
N35 G0 X38.118 Y38.4
N40 G43 Z15. H4
N45 G1 Z-1.635 F500.
N50 Z-3. F508.
N55 X37.8
N60 G3 X37.5 Y38.1 I0. J-0.3
N65 X38.7 Z-3.5 I0.6 J0. F500.
N70 X37.5 Z-4. I-0.6 J0.
N75 X38.7 Z-4.5 I0.6 J0.
N80 X37.5 Z-5. I-0.6 J0.
N85 X38.7 Z-5.5 I0.6 J0.
N90 X37.5 Z-6. I-0.6 J0.
N95 X38.7 Z-6.5 I0.6 J0.
N100 X37.5 Z-7. I-0.6 J0.
N105 X38.7 Z-7.5 I0.6 J0.
N110 X37.5 Z-8. I-0.6 J0.
N115 X38.7 Z-8.5 I0.6 J0.
N120 X37.5 Z-9. I-0.6 J0.
N125 X38.7 Z-9.5 I0.6 J0.
N130 X37.5 Z-10. I-0.6 J0.
N135 X38.7 Z-10.5 I0.6 J0.
N140 X37.5 Z-11. I-0.6 J0.
N145 X38.7 Z-11.5 I0.6 J0.
What I don't understand is in the Fusion post pull down, I turned off tool change and anything else to do with tools.
I apparently don't understand what Linuxcnc needs to run a job properly. If someone could explain this, I would be grateful
(SPOILBOARD HOLES)
N15 G21
(BORE1)
N20 T4 M6
N25 S12000 M3
N30 G54
N40 G43 Z15. H4
N50 Z-3. F508.
N55 X37.8
21 May 2021 01:56 #209720
by BigJohnT
Replied by BigJohnT on topic Unexpected Results - Wasteboard
If you don't set the path blending in your preamble (which I don't see one) then LinuxCNC goes as fast as possible without regard to path.
linuxcnc.org/docs/2.8/html/gcode/g-code.html#gcode:g64
gnipsel.com/linuxcnc/g-code/gen01.html
JT
JT
- Jeff_in_Wa
21 May 2021 03:29 #209723
by Jeff_in_Wa
Replied by Jeff_in_Wa on topic Unexpected Results - Wasteboard
I finally feel like I'm getting somewhere! Wow! John, I'm wondering if you would like to come here for vacation, like now!
My wife and I just read this reply to my question and are so encouraged. We had a feeling there was something wrong with the gcode.
Does this mean everytime I create a Fusion Post, I need to go in and add these codes? Can I do this somewhere in one of the files? .ini maybe?
And lastly, would this lack of preamble possibly cause the issues we are having?
- Jeff_in_Wa
21 May 2021 04:17 #209728
by Jeff_in_Wa
OMG!!!
Hours and hours and hours of searching the .ini, .hal files
OMG it's working!!!
Thank you so much!
You've taken a nightmare of a project to completion
So grateful
OMG it's working!!!
Thank you so much!
So grateful
21 May 2021 19:47 #209790
You can put it in the INI as a STARTUP_GCODE but it would be better to add it to the Fusion Config.
There is a version of the Fusuion postprocessor here which inserts G64:
forum.linuxcnc.org/fusion-360/36097-fusi...ing-post-with-g64-pn
Replied by andypugh on topic Unexpected Results - Wasteboard
The following user(s) said Thank You: BigJohnT
- Jeff_in_Wa
21 May 2021 21:05 #209803
by Jeff_in_Wa
I will give this post a try. Thank you Andy
Time to create page: 0.715 seconds
