axisui.set-mdi-mode not showing in Show Hal Config
01 Dec 2013 19:50 #41271
by Rick G
axisui.set-mdi-mode not showing in Show Hal Config was created by Rick G
Just set up a new computer with 2.6 Master run in place using Git.
Getting ready to set up the joystick and went to Show Hal Configuration and axisui.set-mdi-mode no longer appears.
Anyone else notice this?
Rick G
Rick G
01 Dec 2013 20:04 #41272
by cncbasher
Replied by cncbasher on topic axisui.set-mdi-mode not showing in Show Hal Config
Rick , there has been some changes i believe it's now halui.mode.mdi.pin and also conversly the name change to halui.mode.manual.pin
The following user(s) said Thank You: Rick G
01 Dec 2013 23:16 - 01 Dec 2013 23:26 #41275
by dgarrett
Replied by dgarrett on topic axisui.set-mdi-mode not showing in Show Hal Config
This change to git-master was the result of conversations on
the dev list and irc:
emc.devel:
search.gmane.org/?query=Add+current+mode...utions.emc.devel---A
irc:
emc.mah.priv.at/irc/%23linuxcnc-devel/2013-11-26.html
commits:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...a4c4e3c4ba29fb0e5246
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...6b15552825018b55726d
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...4d37d21f8b1458ff28d0
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...d66b08a8413788d8b3f1
emc.devel:
irc:
commits:
Last edit: 01 Dec 2013 23:26 by dgarrett.
02 Dec 2013 19:52 #41298
by Rick G
Replied by Rick G on topic axisui.set-mdi-mode not showing in Show Hal Config
Dave & Dewey,
Thank you.
I have been using halui.mode.mdi and halui.mode.manual for some time now on my joypad / pendant.
The problem was that the Axis gui could come out of sync which could cause problems with the program and the display.
www.linuxcnc.org/index.php/russian/forum...manual-mode-and-back
So when using the pendant to switch modes we also used axisui.set-mdi-mode and created a new pin axisui.set-manual-mode to also switch Axis.
This is a big improvement and makes the hal file cleaner and upgrading easier.
Rick G
Thank you.
Rick G
03 Dec 2013 06:53 #41303
A more direct link to the area of interest:
emc.mah.priv.at/irc/%23linuxcnc-devel/2013-11-26.html#17:54:55
(You can click on a timestamp and get a timestamped URL).
Replied by andypugh on topic axisui.set-mdi-mode not showing in Show Hal Config
irc:
Time to create page: 0.079 seconds
