odd problem
06 Jan 2016 05:22 #67948
by KobeYang
odd problem was created by KobeYang
Dear Sir,
I use emc2.4.7 in ubuntu 10.04 LTS for a long time.By accident I found an odd problem.After I use the "F3"&"F5" to change the Manual and MDI interface frequently,the MDI command edit can't be input the code.the accel key ("F3"&"F5" )also become invalid.Can anybody help me?Thanks a lot.
PS:when I update the emc2.4.7 to Linuxcnc2.5.4,the problem remains unresolved.
06 Jan 2016 09:39 #67953
by cncbasher
Replied by cncbasher on topic odd problem
you need to move on to 2.7 , ubuntu 10.04 is now old and past support , so at some stage your going to have to upgrade to debian & 2.7 .
as your using 2.5.4 i presume your using an old pc , you would be best to resolve and update your hardware
amongst also have the advantages of the newer functions .
trying to support ubuntu has now stopped , in favour of debian wheezy , and the newer jessie shortly
updating will solve your problem .
- Thank you received: 1369
06 Jan 2016 14:17 #67966
Replied by Todd Zuercher on topic odd problem
That said, I still have a machine running on its original Ubuntu 10.04 installation which started on (emc2)2.3 and is currently running 2.7. So you may not have to update your OS or hardware inorder to update to 2.7. (At least not at the moment.) That machine of mine relies on an old ISA card for I/O, and I am not looking forward to the day that I must update its hardware.
07 Jan 2016 05:58 #68009
by Rick G
Replied by Rick G on topic odd problem
Have you tried downloading and booting from the current live / install image and see if the problem persists in the current version?
linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html
Rick G
Rick G
07 Jan 2016 12:54 #68013
How frequently?
I use the F3 key a lot, but I don't have an F5 key, so always have to click the GUI.
Replied by andypugh on topic odd problem
How frequently?
Time to create page: 0.295 seconds
