remove 3d graphic rotating constraint
28 Feb 2016 23:30 #70781
by Cheech
remove 3d graphic rotating constraint was created by Cheech
HI guys
Im new to LinuxCNC and I have to say I am in love with the new TP. I am running LCNC2.7.0 on Debian Wheezy.
I wish making screen modifications was easier, to be able to do it one needs to spend serious time in learning. Can someone make a screen editor program please?
- I will start asking if there is a way to remove the constraint on the rotate mode where we can only rotate 180 degrees about the XY plane. In other words.. the camera can only look at the gcode from the top perspective and not look from underneath.
- And also Is there is a way to readjust the initial view rate (camera zoom) so I the part looks bigger on screen..
I am hoping this is something we could implement within the .axisrc (screen customization file).
also a glitch I noticed..
-When i switch from pan mode to rotate mode, usually the first click of the mouse to start rotating the view causes the zoom to change and makes the part very small on the screen requiring you to zoom in again to readjust the view.
Francisco
Francisco
01 Mar 2016 10:15 #70851
You can edit the GScreen GUI with the Glade Editor.
linuxcnc.org/docs/2.7/html/gui/gscreen.html
Replied by andypugh on topic remove 3d graphic rotating constraint
Time to create page: 0.082 seconds
