Tool lenght sensor configuration
19 Oct 2016 00:41 #81815
by lopataos
Tool lenght sensor configuration was created by lopataos
Hello hard working comunity.
I have recently switch to linuxcnc and I cant manage to configure the tool lenght sensor.
Can anyone recommend anither gui and kindly explain more about the tool sensor.
As the machine is my build, I want to have fixed position for measuring tools, and make a little macro which will measure every tool and set to predefined offset (same for each tool).
I will post more about my machine and the tool sensor.
Cheers
Marko
Cheers
Marko
- Thank you received: 5927
19 Oct 2016 02:11 #81818
Replied by tommylight on topic Tool lenght sensor configuration
Here are some useful links, regarding tool length sensors,
forum.linuxcnc.org/forum/10-advanced-con...tool-lengh-touch-off
forum.linuxcnc.org/forum/38-general-linu...-length-measurements
forum.linuxcnc.org/forum/49-basic-config...9187-work-with-probe
forum.linuxcnc.org/forum/38-general-linu...e-manual-tool-change
linuxcnc.org/docs/html/gui/gmoccapy.html
The following user(s) said Thank You: lopataos
19 Oct 2016 06:58 #81823
by Rick G
Replied by Rick G on topic Tool lenght sensor configuration
04 Nov 2016 00:17 - 04 Nov 2016 00:23 #82408
by lopataos
Replied by lopataos on topic Tool lenght sensor configuration
Thank you fellas, I really appreciate your help.
I have made some progress. Some of this links did help, but I still have a lot of questions.
I have made an adjustment on my GUI, and included .xml file in machine.ini and buttons apeared, but functionality fails.
The scripts in the buttons dont work for me, so I have made my own script for my machine.
Two questions:
1. How do I link my custom buttons to my script.
2. Exlpanation of problem.
My absolute 0 is on the top of my Z axis and tool lenght sensor is in a fixed position leveled with my initial work table.
When the tool is zeroed, it position is -113.xxx , and I want that temp coordinate to be my new zero. I will also include command to ask me what is the offset from the top of the work piece (work table = zero ; work piece thickness = offset)
What command calculates the current position and makes it zero on another temp coordinates.
I hope I made the issue clear
Thanks again
Marko
Two questions:
Thanks again
Marko
Last edit: 04 Nov 2016 00:23 by lopataos.
07 Nov 2016 12:16 #82535
One of the G10 options.
G10 is a funny command, it does different things depending on whether it is L1, L10, L2 or L20.
Most other commands that are mutable like that would use G10, G10.1, G10.2 etc.
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g10-l1
Replied by andypugh on topic Tool lenght sensor configuration
27 Nov 2016 11:59 - 27 Nov 2016 12:00 #83360
by lopataos
Hey there fellas
Machine is doing great, and I most fascinated with the accuracy and reliability. Position accuracy and positioning is lower than 0.01 on 150 mm, and around 0.02 on 550 mm.
Here are some short videos of machining aluminium 7075-T651
Last edit: 27 Nov 2016 12:00 by lopataos.
27 Nov 2016 17:56 #83372
Nice! Good work.
Time to create page: 0.095 seconds
