Retrofitting WEEKE BP05
23 Jul 2018 12:36 #114698
by urkee
Retrofitting WEEKE BP05 was created by urkee
Does anybody know is there option to remove third zero in AXIS DRO (to downgrade precision in mm) i think it could help us to make good PID tuning. We have problem, machine moves jerky and vibrates when standstill. Weeke is woodworking machining centre with 0.006375mm encoder count, and 0.00mm DRO could make things easier that could be good option for all woodworking machines.
Link to original post:
forum.linuxcnc.org/27-driver-boards/2904...bp05?start=30#114697
- Thank you received: 5988
23 Jul 2018 12:46 #114701
Replied by tommylight on topic Retrofitting WEEKE BP05
No double posting please. You have several replies on the original thread !
Removing a 0 in DRO will not fix the problems you have in your settings.
- Thank you received: 1370
23 Jul 2018 13:08 #114704
Replied by Todd Zuercher on topic Retrofitting WEEKE BP05
The precision displayed on the user interface, actually has nothing to do with the precision actually used in Linuxcnc. So changing what the display shows will have no effect on what is actually physically happening. (Linuxcnc uses double precision floats for all the motion control.)
Time to create page: 0.103 seconds
