Axis in parallel to external MDI comands --> Goal TCP/IP commands
- ChrisSchwFn
21 Jan 2019 20:59 #124566
by ChrisSchwFn
Hello CNC folks,
I am new to the topic of linuxcnc and I have a few questions to the pros of you. My goal is to get the complete control of my milling machine with an external computer over TCP IP commands. To achive this a startet a simple python programm by using the linuxcnc library. It was no problem form me to read out all the information from the machine, except setting something with the mdi methode.
I googled a lot and tryed out several approaches to execute a simple command, but without any succes. Here is what i did:
I appreciate any advice from you Folks,
Best regards,
Chris
- I started the axis gui and init the machne. I run a python script to execute mdi commands --> no success - made all suggested checkings (no estop & enabled & homed and (s.interp_state == linuxcnc.INTERP_IDLE)
- I tryed out the same python script, without axis --> no success, becaus I was not able tho change the Mode
- Do i have to configre something to allow the external access to the machine? - I read about an channel somewhere deep in the configuration to allow the access from python, is that true?
- Is there a better way to send tcp/ip command to the axis gui, by writing my own little broker server and parsing in commands and using the mdi methode?
- Mode was read as MDI
- mdi command seems do be send, but not been executed
- my script had write and execution permission --> no success
- Q: does the axis gui block external mdi commands such as a python programm or MDI?(in bash)?
- I have the feeling something is blocking my commands
- If yes, may somemone help me out, where to do the config and how?
Best regards,
Chris
22 Jan 2019 14:13 #124614
by pl7i92
Replied by pl7i92 on topic Axis in parallel to external MDI comands --> Goal TCP/IP commands
Hi you can use Either MESA Stuff like 7i92 or 7i80 7i76e/D
or a ethercat
you can provide standard TCP to the Hal module
HAL needs to be in as it is realtime
you coudt also use limit3 as a driver for the mashine and a python component to translate the TCP
BUT this is not a real mashine setup and the e-stop might break your mashine bevor you get notice
or a ethercat
22 Jan 2019 16:02 #124622
When you say "linuxcnc library" do you mean:
linuxcnc.org/docs/2.7/html/man/man1/linuxcncrsh.1.html
Replied by andypugh on topic Axis in parallel to external MDI comands --> Goal TCP/IP commands
- ChrisSchwFn
29 Jan 2019 09:11 #125146
by ChrisSchwFn
Replied by ChrisSchwFn on topic Axis in parallel to external MDI comands --> Goal TCP/IP commands
i used the lib "linuxcnc" with python so far.
But linuxcncrsh seems good. I will give this a try and let you know my progress. Thanks for the hint.
Time to create page: 0.078 seconds
