simulation
06 Nov 2023 16:49 #284718
by bkt
Replied by bkt on topic simulation
from what I know dryrun was a function implemented by the "legendary" dgarret ... who however left nothing of his "dev" repos except what was already implemented in master (switchkins for example, or adaptive-feed). ...now unfortunately, at the time I was intrigued...but I didn't clone the repositories...so that apparently got lost. It's been a long time... I don't know if I downloaded it... if I found it I could make it available... but I'm not sure if dgarrett appreciates it... it would be nice if he had his say......
At least think is only necessary make a sim encoder for every joint and switch feedback signal with simulated one .... obviusly need to switch from sim.ini to real.ini with button or somethings of similar....
regards to all
regards to all
06 Nov 2023 17:28 #284720
Replied by Aciera on topic simulation
I haven't reread the thread but if I remember correctly it would let you run your gcode without machine movement.is the 'dryrun' branch/feature (not-yet-added to LCNC) a simulation or a 'dryrun' with machine movement?
08 Nov 2023 11:02 #284854
by sivaraj
Replied by sivaraj on topic simulation
github.com/LinuxCNC/linuxcnc/tree/e4f42a...067eb65be036162c4ea7To clarify - I can't find anything on GitHub as the links earlier in the thread are dead, and a search for 'dryrun' in GH doesn't come up with anything.
Time to create page: 0.135 seconds
