How does axisui work?
23 Mar 2021 08:48 - 23 Mar 2021 09:07 #203364
by Jialan
How does jogging work? was created by Jialan
hii
I need an external signal to control the X axis forward and backward,
I use linuxcnc.org/docs/html/man/man9/motion.9.html#AXIS%20PINS ,but it any action
how to jog work for hal
thank
thank
Last edit: 23 Mar 2021 09:07 by Jialan.
23 Mar 2021 10:15 - 23 Mar 2021 10:22 #203372
Replied by Aciera on topic How does jogging work?
If I understand this correctly then you want to use an external signal to jog the x axis.
For that you could use 'halui.axis.x.plus' and 'halui.axis.x.minus' linuxcnc.org/docs/html/man/man1/halui.1.html:
Note this will only let you jog after homing. If you need jogging before homing as well you would need to add 'halui.joint.N.plus' and 'halui.joint.N.minus' as well (with N being the joint number for your x-axis):
net jog-x-pos <= your_signal_plus => halui.axis.x.plus
net jog-x-neg <= your_signal_minus => halui.axis.x.minus
net jog-x-pos <= your_signal_plus => halui.axis.x.plus => halui.joint.N.plus
net jog-x-neg <= your_signal_minus => halui.axis.x.minus => halui.joint.N.minus
Last edit: 23 Mar 2021 10:22 by Aciera.
The following user(s) said Thank You: Jialan
23 Mar 2021 10:33 #203375
by Jialan
Replied by Jialan on topic How does jogging work?
I am fairly new to LinuxCNC,the code How to use ,I need to one clack to forward or backward
23 Mar 2021 12:16 #203382
Could you post your .hal and .ini files please?
- Thank you received: 5944
23 Mar 2021 17:02 #203410
Replied by tommylight on topic How does jogging work?
Changed the OP title
24 Mar 2021 01:08 - 24 Mar 2021 06:46 #203477
by Jialan
I want to use check code(.hal 39row) to control motor
use halui to hal or ini ?
thank
thank
Last edit: 24 Mar 2021 06:46 by Jialan.
24 Mar 2021 01:44 - 24 Mar 2021 06:45 #203478
by Jialan
What is the difference between (halui.axis.jog-speed) and (halui.joint.jog-speed)
Last edit: 24 Mar 2021 06:45 by Jialan.
24 Mar 2021 05:58 #203484
halui.joint.jog-speed is the jog speed before homing and halui.axis.jog-speed is the jog speed after homing.
See this recent thread for more on the difference between joint-mode and axis-mode:
forum.linuxcnc.org/show-your-stuff/41926...axis?start=10#203212
It's done in hal
Note that you will need some sort of binary signal to replace 'your_signal_plus' and another signal to replace 'your_signal_minus'
Do you want to use external buttons to jog? How to you bring the signals into LinuxCNC?
It's done in hal
24 Mar 2021 06:26 - 24 Mar 2021 06:45 #203485
by Jialan
yes I want to two button to jog forward and backward
I'll try it
thank
I'll try it
thank
24 Mar 2021 06:45 #203486
by Jialan
I write net jog-x-pos <= HATBUS.Axis0-enable(my signals) => halui.axis.x.plus
but linuxcnc error code 'halui.axis.x.plus' does not exist
so what to work
so what to work
Time to create page: 0.153 seconds
