How does axisui work?
24 Mar 2021 07:18 - 24 Mar 2021 08:45 #203488
by Jialan
Replied by Jialan on topic How does jogging work?
I write net jog-x-pos <= HATBUS.Axis0-enable(my signals) => halui.axis.x.plus
but linuxcnc error code 'halui.axis.x.plus' does not exist
Last edit: 24 Mar 2021 08:45 by Jialan.
24 Mar 2021 08:47 - 24 Mar 2021 08:48 #203498
by Jialan
thank Aciera
I think I understand
thank
thank
Last edit: 24 Mar 2021 08:48 by Jialan.
24 Mar 2021 16:58 #203521
Ah yes you are missing the entry 'HALUI = halui' in the [HAL]-section of your ini. So add it like this:
After that the halui pins should be available.
Replied by Aciera on topic How does jogging work?
[HAL]
# Add the halui user interface
HALUI = halui
# The run script first uses halcmd to execute any HALFILE
# files, and then to execute any individual HALCMD commands.
# list of hal config files to run through halcmd
# files are executed in the order in which they appear
HALFILE = MonoPump.hal
# list of halcmd commands to execute
# commands are executed in the order in which they appear
#HALCMD = save neta
The following user(s) said Thank You: Jialan
26 Mar 2021 02:19 #203661
by Jialan
Replied by Jialan on topic How does axisui work?
By the way ,I use axisui.jog.increment net to halui.joint.0.increment
but linuxcnc is don't exist ,Why
26 Mar 2021 07:38 #203674
Replied by Aciera on topic How does axisui work?
The axisui. pins don't exist until after the axis-gui has been loaded so all your hal code that requires pins from GUIs, like axisui pins, need to be in a postgui.hal file.
1. Create a file in your 'config' folder. For example 'MonoPump_postgui.hal'
2. Copy your line inside 'MonoPump_postgui.hal' :3. Save 'MonoPump_postgui.hal'
4. Add this line to the [HAL] section in your INI-file:
This line makes sure that MonoPump_postgui.hal is executed after the GUI (ie AXIS in your case) has been loaded.
net yoursignalnamehere axisui.jog.increment halui.joint.0.increment
POSTGUI_HALFILE = MonoPump_postgui.hal
26 Mar 2021 08:31 #203678
by Jialan
I will try it ,thank Aciera
06 Apr 2021 09:32 - 06 Apr 2021 09:32 #205055
by Jialan
my jog is working,but how does my jog is end
Last edit: 06 Apr 2021 09:32 by Jialan.
06 Apr 2021 10:53 #205070
Not sure what you mean there. Does the jog movement not end when you release the button?
07 Apr 2021 03:15 #205226
by Jialan
when i release the button ,jog working to halui code(halui.joint.0.increment 5 and halui.joint.0.increment-plus TRUE) .
How know was end ,use linuxcnctop.py 'state' = (1 or 2 )?
Time to create page: 0.136 seconds
