5 DOF Robotic Arm
I need your help.
I have a 5 DOF robotic arm and I am having problems with the axis in the GUI. Even though I have 5 rotary axes, the Preview shows me 5 linear axes.
I tried swapping the order of the axes in the GEOMETRY section of the HAL file like:
" GEOMETRY = ABXYZ " instead of "GEOMETRY = XYZAB"
but nothing done.
Any suggestions?
Please, write soon!
Not exactly sure what you expect to see but as far as I know XYZ will always be displayed as linear and ABC as rotary.
Can you post a screen shot?
I would like to get a preview like the one in this video:
I'm not in the lab now so I can attach the screenshot, I'll do it as soon as possible.
My aim is to have the right trajectory of the end effector along the way
Are you aware that you need a kinematic file to translate your joint position to cartesian coordinates?
The problem is that the actual trajectory of the final effector doesn't match what I see in the preview.
Is this a vismach visualization or just the trajectory preview in AXIS?
Any ideas?
Can you post your ini and hal?
- Thank you received: 5944
GEOMETRY = xyz
Try changing that.
