5 DOF Robotic Arm
31 Mar 2021 10:29 #204200
Take a look at the sample config sim-axis-vismach-puma
That is a Vismach model (like yours) set up with kinematics inside linuxcnc.
"puma" uses a single-purpose kineamatics - "pumakins"
"puma560" uses the general-purpose "genserkins".
You could probably use either.
Also, the docs:
linuxcnc.org/docs/2.8/html/motion/kinematics.html
linuxcnc.org/docs/2.8/html/motion/dh-parameters.html
And possibly:
linuxcnc.org/docs/2.8/html/motion/5-axis-kinematics.html
Replied by andypugh on topic 5 DOF Robotic Arm
Okay, I try using Vismach model and I will report what happens.
I don't use LinuxCNC kinematics beacuse I don't know how to compute it there, where can I find some information?
Also, the docs:
And possibly:
31 Mar 2021 15:48 #204237
Replied by Aciera on topic 5 DOF Robotic Arm
I don't understand, when I asked you
your answer was:
Now you write this:
Are you aware that you need a kinematic file to translate your joint position to cartesian coordinates?
your answer was:
Yes, in fact when I run the g-code, the robot moves correctly.
Now you write this:
