axis vs touch offs.
26 Nov 2021 18:27 #227668
by Gene1934
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page <geneslinuxbox.net:6309/gene>
Replied by Gene1934 on topic axis vs touch offs.
found it!!!, My bad, hold the biscuits, I had used X and Z in the signal names in the postgui.hal but I had xtoggleout and ztoggleout in the main hal.
A noticeable lag in the update times but its working, might need to generate a longer pulse but that is not a problem to do.
And I could probably remove that timeout function that caused the need for that pulse in the first place, I'd added the timeout but have since found LCNC didn't need to shut the dials off as it ignores them anyway if its doing anything else. OTOH, it also protects it unless you intentionally push the button to reactivate them once timed out. And that button is hard to push, too hard in fact .
So if something brushes against the dial while changing tools or whatnot, its timed out and ignored.
Thanks guys, I think this is going to work.
- Thank you received: 5935
26 Nov 2021 22:36 #227700
Was i supposed to not eat them ?
Replied by tommylight on topic axis vs touch offs.
Holding them and eating them !My bad, hold the biscuits,
26 Nov 2021 22:59 #227704
by Gene1934
As in bad dog, no biscuit. :o)
26 Nov 2021 23:34 #227710
by Gene1934
I've been playing some more and it appears to update the radio buttons on the falling edge of the strobe which I had set for 300 milliseconds. At a 50 ms pulse width setting, its pretty close to real time, good enough for me. Thank you again everyone that contributed.
13 Dec 2022 17:15 #259334
by Bidul
Replied by Bidul on topic axis vs touch offs.
Thank you so much! I have been searching this for hours and hours....
So simple when we know!
