ESC in axis 2.9.0 is that a proper behaviour
05 Mar 2022 16:10 #236439
by radom
ESC in axis 2.9.0 is that a proper behaviour was created by radom
I have a question,
lets say I have a lathe and executing code/mdi command, spindle is running and I press ESC - everything stops ok, I click touch off, enter number and then spindle turns on by itself
which I think is not ideal
2.8.2 didn't do that
is that a intended change or a bug or a mistake in my config
05 Mar 2022 20:35 #236451
Replied by cmorley on topic ESC in axis 2.9.0 is that a proper behaviour
That is a bug.
The following user(s) said Thank You: radom
10 Mar 2022 00:01 #236796
Replied by andypugh on topic ESC in axis 2.9.0 is that a proper behaviour
13 Mar 2022 11:43 #237102
by radom
Replied by radom on topic ESC in axis 2.9.0 is that a proper behaviour
I don't know what that was,
I can't reproduce it anymore
If I figure it out I will report it as a bug
thanks
thanks
15 Mar 2022 17:07 #237346
I would guess that this is related to touching-off diameter when in constant surface speed mode.
29 Mar 2022 17:53 - 29 Mar 2022 17:54 #238632
by radom
I don't know what is happening
I mostly use 2.8.2 but when I open 2.9.0 one day the "bug" is present and another day I cannot reproduce it
and I'm doing the same thing after opening axis, mdi - m3 - esc - touch off
if it works it works with both g96 or g97 doesnt matter
Last edit: 29 Mar 2022 17:54 by radom.
30 May 2022 16:37 #244226
by radom
Ok something different but similar
could someone reproduce this in 2.9.0 axis:
MDI - M3 s100 - spindle starts
press ESC - spindle stops, I can see M5 in Active g-codes in axis
mdi S50 enter - spindle starts
31 May 2022 23:39 #244322
Yes, I see the same thing with 2.9.
Oddly, not with 2.8. Which is a bit unexpected as if there was a bug in spindle handling I would have expected it to be related to the multispindle changes, but those are in 2.8 too.
31 May 2022 23:40 #244323
Are you building LinuxCNC from source, or using packages?
(If from source, do you have the time to do a git bisect to find when the issue was introduced?)
01 Jun 2022 01:12 #244333
I bet this is my code. I changed the spindle to change state on m3/4/5 rather then on s=0/s!=0.
I probably didn't look at abort, which probably stops the spindle by settting S to 0 but not M to 5.
Do you know where the abort code lives - I will take a look.
Time to create page: 0.217 seconds
