ESC in axis 2.9.0 is that a proper behaviour
01 Jun 2022 08:34 #244352
Replied by andypugh on topic ESC in axis 2.9.0 is that a proper behaviour
github.com/LinuxCNC/linuxcnc/blob/master...sk/taskintf.cc#L1901
Looks likely, and calls:
github.com/LinuxCNC/linuxcnc/blob/master...tion/command.c#L1631
Though that all looks OK. Possibly the issue is that ESC is not calling spindleAbort?
01 Jun 2022 15:36 #244379
by radom
from source,
I don't know how to use git bisect
if you can tell me what to type at the terminal I will do it
Replied by radom on topic ESC in axis 2.9.0 is that a proper behaviour
Are you building LinuxCNC from source, or using packages?
(If from source, do you have the time to do a git bisect to find when the issue was introduced?)
from source,
02 Jun 2022 10:58 - 02 Jun 2022 11:02 #244439
The bisect process is fairly simple, but it needs a "good" and a "bad" git tag, and finding the "good" one is something that I can't do until I get back to my LinuxCNC machines next week.
Last edit: 02 Jun 2022 11:02 by andypugh.
03 Jun 2022 23:23 #244550
My next thought is that the interpreter state is not changed from m3 to m5
I see a delay in AXIS update of the active gcodes but entering an s either way will start the spindle.
Replied by cmorley on topic ESC in axis 2.9.0 is that a proper behaviour
Yes that seems right.andypugh post=244352 userid=723https://github.com/LinuxCNC/linuxcnc/blob/master/src/emc/task/taskintf.cc#L1901
