Can't install camview in buster
30 Oct 2022 17:05 - 30 Oct 2022 17:10 #255461
by seuchato
Can't install camview in buster was created by seuchato
Hi all
I do have a mobius one camera, which I got working, including crosshairs in axis up and working, following the instruction here: wiki.linuxcnc.org/cgi-bin/wiki.pl?Axis_Embed_Video.
However, I fail to get camview installed. the wiki page referred to, points to psha.org.ru/b/camview-emc.html. Following that page I did:
Why do I get this error?
greez
chris
echo "deb http://psha.org.ru/debian/ buster contrib" >> /etc/apt/sources.list
cat /etc/apt/sources.list | grep psha
LANG=C apt-key adv --fetch-keys http://psha.org.ru/debian/pubkey.gpg
Executing: /tmp/apt-key-gpghome.KOn68NhVoU/gpg.1.sh --fetch-keys http://psha.org.ru/debian/pubkey.gpg
gpg: requesting key from 'http://psha.org.ru/debian/pubkey.gpg'
gpg: key 371656DF65774D8D: "Debian Archive (autosign) <debian@psha.org.ru>" not changed
gpg: Total number processed: 1
gpg: unchanged: 1
# The unchanged is because that printout is from second run
# imho it says, the key is successfully installed
LANG=C apt update
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 http://psha.org.ru/debian buster InRelease
Hit:5 http://www.linuxcnc.org buster InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
2 packages can be upgraded. Run 'apt list --upgradable' to see them.
apt-get upgrade
# output omitted as it is unrelated
LANG=C apt-get install camview
E: Unable to locate package camview
greez
chris
Last edit: 30 Oct 2022 17:10 by seuchato. Reason: added missing stuff
30 Oct 2022 22:26 #255501
Replied by andypugh on topic Can't install camview in buster
At the very bottom of that Wiki page it says "Last edited March 28, 2011 10:28 pm by Psha" so it might well be very out of date.
This one appears to be newer: wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding_Camview
More up-to-date still is probably "cam_align" Try searching the forum for that.
30 Oct 2022 23:28 #255515
by Bari
Replied by Bari on topic Can't install camview in buster
forum.linuxcnc.org/38-general-linuxcnc-q...-with-linuxcnc-2-8-0
qtvcp uses opencv for webcam alignment in 2.8+
forum.linuxcnc.org/38-general-linuxcnc-q...-8-0?start=20#241967
01 Nov 2022 19:42 #255689
by seuchato
Replied by seuchato on topic Can't install camview in buster
Hi again
Not sure this is still the right thread. If not, : @ mods: feel free to move it to a new thread, tia
Fiddled around a bit and did a lot of reading too (doing the very rtfm smiley, shame on me)
Besed on the suggetstions of both, andypugh and bari, I dropped all camview stuff in favour of cam_align, and: I got some success!
I have a tab in axis, showing cam pic, simple cross hairs and a small circle. downside: takes quite some time to start axis, about 30 secs or so. Just a bit of an annoyance, not an issue though. If I start from commandline, I see a ton of messages:
Questions:
Is this normal?
If not: how to remedy?
Greez
chris
Questions:
Is this normal?
Greez
chris
01 Nov 2022 19:44 #255692
Can you attach the messages? Otherwise we are just guessing.
01 Nov 2022 21:29 #255696
by seuchato
Andy
I seem not be able to add stuff like in attached file "messages.txt"
Greez
Greez
02 Nov 2022 00:38 #255726
Where does it spend the time? I would guess at the "Waiting for component 'qtvcp_embed' to become ready..." stage?
You can make some of the cruft disappear by adding the missing items to the [DISPLAY] section of the INI {and probably should, just so you end up with sensible values in the GUI).
I don't know how serious the bad-drawable errors are. Are they regular and continuous?
02 Nov 2022 04:36 #255749
Replied by cmorley on topic Can't install camview in buster
There should be a sim: axis/qtvcp/qtvcp_tab available.
Can you try it and see if there is a big delay too ?
02 Nov 2022 05:20 #255753
by phillc54
Replied by phillc54 on topic Can't install camview in buster
It works on 2.8.4 here without any noticeable startup delay, the "BadDrawable" messages only seem to appear during shutdown.
I do see these at the top of your messages, I have no idea what they are or whether they cause any issues.
# handle_includes(): <35> found #INCLUDE with no filename
# handle_includes(): <36> CANNOT READ nosuchfile
02 Nov 2022 05:51 #255755
maybe it has to do with this?
linuxcnc.org/docs/devel/html/config/ini-...html#sub:ini:include
