METRIC / SAE Indicator for pyVCP
26 Nov 2016 04:18 #83326
by Askjerry
METRIC / SAE Indicator for pyVCP was created by Askjerry
Is there some kind of a hal pin that I can look at and point to a graphic so that I have a quick indication if the machine is in SAE or METRIC mode?
I want to make a pyVCP graphic... yellow with "METRIC" or blue with "INCH" that is pretty easy to see... I know how to make graphos. net them... etc... just looking for something like halui.mode.is-mm or similar that will give me a true/false.
Exists???
Jerry
Exists???
Jerry
- Thank you received: 1369
26 Nov 2016 14:57 #83342
Replied by Todd Zuercher on topic METRIC / SAE Indicator for pyVCP
No there isn't a hal pin that I know of. If you use a GladeVCP though it is fairly simple to uses a Linuxcnc Stat object to get it. Another option would be a custom hal component to get it.
26 Nov 2016 15:56 #83345
by Askjerry
Replied by Askjerry on topic METRIC / SAE Indicator for pyVCP
Yeah... I haven't figured out custom HAL yet... I know there is a list of active G-Codes shown in the MDI section... if I could find out where that variable was and look for G20 or G21... but I don't have the time to dig into that quite yet. I was looking for a quick indicator... guess it's going to turn into a "project" instead.
Thanks,
Jerry
Thanks,
Jerry
28 Nov 2016 01:15 #83386
by screwtop
Replied by screwtop on topic METRIC / SAE Indicator for pyVCP
Interesting question. I found a couple of pertinent global variables, but don't know that you can access these from pyVCP:I had a rummage around in the source and couldn't find a HAL pin for this. It would be useful, though, and I think probably should exist for completeness. I found the following possibly useful leads in src/emc/task/emccanon.cc:and also in src/emc/usr_intf/axis/extensions/emcmodule.cc:I haven't written a custom HAL component either, but maybe this would be a good one to start with...
#<_metric> - Return 1 if G21 is on, else 0.
#<_imperial> - Return 1 if G20 is on, else 0.
emcStatus->task.programUnits
emcStatus->motion.traj.linearUnits
{(char*)"linear_units", T_DOUBLE, O(motion.traj.linearUnits), READONLY},
28 Nov 2016 01:22 #83387
by screwtop
Also, it seems it's not just a question of mm or inches: in places the code has support for mm, cm, inches, custom, and auto! But the core EMC code seems to be limited to mm, cm or inches for the canonical units; this from src/emc/nml_intf/canon.hh:
typedef int CANON_UNITS;
#define CANON_UNITS_INCHES 1
#define CANON_UNITS_MM 2
#define CANON_UNITS_CM 3
28 Nov 2016 05:50 - 28 Nov 2016 05:51 #83389
Replied by cmorley on topic METRIC / SAE Indicator for pyVCP
Here is working sample code of a python component for metric (G20/21) status
The python component info is somewhat explained here:
www.linuxcnc.org/docs/2.7/html/hal/halmodule.html
name it metric_status , add it into an appropriate folder ($PATH in a terminal should show you)
and make it executable
One caveat, displayed Gode in a running linuxcnc program, can be wrong because of read ahead.
This one is fairly safe as not too many people change the units mid program.
Hope that helps!
Chris M
#!/usr/bin/env python
import linuxcnc
import hal,time
metric = False
h = hal.component("metric_status")
h.newpin("out", hal.HAL_FLOAT, hal.HAL_OUT)
h.ready()
status = linuxcnc.stat()
try:
while 1:
# update once a second
time.sleep(1)
# poll current status
status.poll()
# search active G codes
# only check whole numbered Gcodes
for i in sorted(status.gcodes[1:]):
if i == -1: continue
if i % 10 == 0:
if i == 210:
metric = True
break
elif i == 200:
metric = False
break
# Update pin
h['out'] = metric
except KeyboardInterrupt:
raise SystemExit
Hope that helps!
Chris M
Last edit: 28 Nov 2016 05:51 by cmorley.
28 Nov 2016 13:39 #83393
by Askjerry
Wow... I'll have to look into this.
Update of the display is not an issue... the main impetus for this was that I went to move the bit 10mm the other day during a job so I typed in G0 X10 expecting the bit to move slightly... as it continued way past where expected and scratched the surface... I realized by buddy had typed in G20 because he prefers inches.
I thought it would be good to have some obvious icon in the pyVCP panel to catch my eye... more than just the text in the little display box that is easily missed. I was hoping for a more "stock" solution... something I could just share with others like, "paste this into your pyVCP panel and you are good." But perhaps this is better... it may force me to learn new tools... new skills, and get a bit deeper into the system.
I'll give it a try sometime this week and report back.
Thanks!
Jerry
Thanks!
Jerry
28 Nov 2016 16:37 #83398
Wouldn't it make more sense to pole the stat.program_units rather than trying to pick out the active g-code something like this?
import linuxcnc
import hal,time
metric = False
h = hal.component("unit_status")
h.newpin("out", hal.HAL_BIT, hal.HAL_OUT)
h.ready()
try:
while 1:
time.sleep(1)
status.poll()
# check program units
if status.program_units == 2:
metric = True
if status.program_units == 1:
metric = False
# Update pin
h['out'] = metric
raise SystemExit
28 Nov 2016 18:05 - 28 Nov 2016 18:06 #83402
by Askjerry
Ultimately, it would be nice if this were a signal standard in HAL.
For example, there is a signal I use called halui.program.is-running which lights up a red bar where the jog buttons of my panel are... at a glance, I can tell that I have some background task running, and that I have to wait. Really simple to implement.
I was hoping there would have been something like halui.units.mm and/or halui.units.inch that I could look for and react to. Generally... to share my advanced pyVCP panels with others. (Doing a YouTube series on LinuxCNC currently.)
So mostly... looking for something a neophyte could easily do. Still wondering if I can somehow hook the #<_metric> variable.
Jerry
Jerry
Last edit: 28 Nov 2016 18:06 by Askjerry.
29 Nov 2016 04:52 #83416
I would assume that because of the read ahead problem - these type of signals were not made.
There is a branch in development that tries to fix the read ahead problem. If this gets merged in the future then pins with this kind of
info would make much more sense.
Chris M
Chris M
Time to create page: 0.443 seconds
