METRIC / SAE Indicator for pyVCP
- Askjerry
- Thank you received: 31
29 Nov 2016 04:58 #83417
by Askjerry
Replied by Askjerry on topic METRIC / SAE Indicator for pyVCP
The read-ahead shouldn't make much difference... it is more of a flag, it is more of a flag when in manual entry mode so you don't type G0 X10 expecting 10mm and get a surprise when it goes 10 inches instead.
When code is running... you are more or less just watching the show... it's when you are manually doing things... that's when it gets interesting.
- Thank you received: 2148
29 Nov 2016 05:15 #83418
Replied by cmorley on topic METRIC / SAE Indicator for pyVCP
it can be important if you stop/abort a program and then restart in the middle.
I agree that metric/imperial settings are rarely changed in the middle of a program.
Chris M
Chris M
- Thank you received: 4640
29 Nov 2016 13:51 - 29 Nov 2016 13:52 #83431
Isn't this more Pythonic:
Replied by andypugh on topic METRIC / SAE Indicator for pyVCP
for i in sorted(status.gcodes[1:]): if i == -1: continue if i % 10 == 0: if i == 210: metric = True break elif i == 200: metric = False break
metric = True if 210 in s.gcodes else False
Last edit: 29 Nov 2016 13:52 by andypugh.
30 Nov 2016 01:20 #83466
yes it is.
My example came from code in gscreen which parses gcode for different reasons.
I was not trying for the best code, just an example.
Chris M
Chris M
