PROGRAM STOP BUTTON - ERROR
03 Feb 2019 20:50 #125608
by Askjerry
PROGRAM STOP BUTTON - ERROR was created by Askjerry
Here is an interesting one...
I have two buttons programmed on a pyVCP panel... PROGRAM RUN and PROGRAM STOP.
I figured out quickly that the PROGRAM RUN button could ONLY be triggered in AUTO mode... so I did this...
CUSTOM_POST_GUI.HAL
That works great...
Now the stop button... it stops... but with an error...
CUSTOM_POST_GUI.HAL
I get the following...
So what am I missing??
Thanks,
Jerry
CUSTOM_POST_GUI.HAL
net panel-pg-run <= halui.program.run <= halui.mode.auto <= pyvcp.PRGM-RUN
That works great...
CUSTOM_POST_GUI.HAL
net panel-pg-stop <= halui.program.stop <= pyvcp.PRGM-STOP
can't do that (EMC_TRAJ_SET_TELOP_ENABLE)
in auto mode with the interpreter idle
Thanks,
Jerry
03 Feb 2019 22:24 - 03 Feb 2019 22:29 #125615
by Grotius
Replied by Grotius on topic PROGRAM STOP BUTTON - ERROR
Maybe, you can try one of this below :
#real mode :
#net estop-out <= iocontrol.0.user-enable-out
#net estop-ext => iocontrol.0.emc-enable-in
#net estop-ext => halui.program.stop
==> net estop-ext => your i/0 pin for emergency brake circuit, i changed to halui for you, but better is choosing a real hardware circuit pin for real machines without simulation. Fail safe.
#simulation mode :
net estop iocontrol.0.emc-enable-in iocontrol.0.user-enable-out
#real mode :
#simulation mode :
Last edit: 03 Feb 2019 22:29 by Grotius.
03 Feb 2019 22:47 #125618
by Askjerry
Replied by Askjerry on topic PROGRAM STOP BUTTON - ERROR
It is not an ESTOP button... we do not want to put the machine in ESTOP mode... although i suppose that is one way to do it.
We simply want to do the same thing as hitting the square stop button at the top of the screen...
If a program is running and you hit this... the program stops. That is what i am attempting to replicate.
Thanks,
Jerry
Thanks,
Jerry
03 Feb 2019 23:03 - 03 Feb 2019 23:13 #125619
by Grotius
Hi Jerry,
Why don't you use a gscreen gui? It makes life easy for you... You can say
"program stop" in python.
Hal.ui command's alway's worked for me. I don't use them because i alway's program in python or c.
I only couple my ethercat side in hal and some stuff that are hal button's from glade without defining them in the gui first, that is more a lazy action. But Gmocappy is more accurate in that way.
Maybe you can try : halui.abort
it does the same as program stop, it's only more written to top level.
Last edit: 03 Feb 2019 23:13 by Grotius.
03 Feb 2019 23:29 #125622
My thought:
EMC_TRAJ_SET_TELOP_ENABLE indicates to me that the machine was in joint mode when you pressed stop.
that is a mode that you can't run a program in - so pressing stop is useless - but I would say linuxcnc should ignore it rather then error on it.
Does this sound likely? (could probably test by keeping track what mode linuxcnc is in with the status program)
If I'm right it would require code changes either in HALUI or better in linuxcnc's motion controller.
In gladevcp we would disable the stop button to limit this possibility, PyVCP can not IIRC.
My 2 cents
Chris M
Replied by cmorley on topic PROGRAM STOP BUTTON - ERROR
Thanks,
Jerry
My thought:
My 2 cents
Chris M
04 Feb 2019 01:23 - 04 Feb 2019 01:27 #125627
by Askjerry
Grotius - That may work... but at the moment I know how to make panels in GLADE and pyVCP... I have not used, and I am not familiar with gscreen gui so I'll have to research it... but most likely I'll go a different route for now. (I'm patching an existing machine.)
The halui.abort may work... and it is easy to try... that will be my first attempt.
cmorley - It is just a standard insttall of LinuxCNC with an X-Y-Z configuration running a typical G-Code file... nothing special.
Thanks,
Jerry
Thanks,
Jerry
Last edit: 04 Feb 2019 01:27 by Askjerry.
04 Feb 2019 02:05 - 04 Feb 2019 02:29 #125628
by phillc54
Replied by phillc54 on topic PROGRAM STOP BUTTON - ERROR
You could try something like:
Cheers, Phill
loadrt and2 count=1
loadrt or2 count=1
addf and2.0 servo=thread
addf or2.0 servo=thread
net is-running-flag halui.program.is-running => or2.0.in0
net is-paused-flag halui.program.is-paused => or2.0.in1
net run-or-pause-flag or2.0.out => and2.0.in0
net stop-button pyvcp.PRGM-STOP => and2.0.in1
net stop-signal and2.0.out => halui.program.stop
Cheers, Phill
Last edit: 04 Feb 2019 02:29 by phillc54.
04 Feb 2019 02:59 #125629
by Askjerry
phillc54 - I could be reading what you have incorrectly... but it looks like you are tying is-running and is-paused as two inputs... which will be true when running... so the stop command would be applied... but I see that as till hitting the error fail as it is going to be in the same state as without checking.
Here is the actual code as it is now...
As you can see... the pyvcp.PRGM-RUN button pushes halui.mode.auto and and the halui.program.run signals... likely in that order. So it gets pushed to AUTO mode, then gets the RUN command... works beautifully.
If I hit the PAUSE button, then hit the STOP button... it works.
So what I would love to do is...
But even removing the PAUSE button and trying it... I still get the error.
I also tried the suggested halui.abort which also failed.
It appears that I need to trigger a pause... then trigger a stop afterward... not sure how to do that. Or figure out what mode the system expects to be in... then do it.
Or... and I don't know if this is possible... fake it out so it thinks the user pressed the ESC key... because that works fine.
Is that possible... point the pyvcp.PRGM-STOP to trigger a keystroke???
Jerry
net panel-spindle-on <= halui.spindle.start <= pyvcp.SPINDLE-START
net panel-spindle-off <= halui.spindle.stop <= pyvcp.SPINDLE-STOP
net panel-pg-pause <= halui.program.pause <= pyvcp.PRGM-PAUSE
net panel-pg-resume <= halui.program.resume <= pyvcp.PRGM-RESUME
net panel-pg-step <= halui.program.step <= pyvcp.PRGM-STEP
net panel-led-spindle <= halui.spindle.is-on => pyvcp.LED-SPINDLE
net panel-led-program <= halui.program.is-idle => pyvcp.LED-PGM-RUN
net panel-pg-stop <= halui.program.stop <= halui.program.pause <= pyvcp.PRGM-STOP
Jerry
04 Feb 2019 04:36 - 04 Feb 2019 04:42 #125632
by phillc54
The intention was to only send a stop command if the program is either running or paused and the stop button (in your panel) is pressed.
I tried the following on both 2.7 and master.
If a program is either running or paused then issue:The program stops without errors.
If a program is stopped then issue:No error messages.
I also found that:Runs the program, halui.mode auto was NOT required, even if the MDI tab was active.
The only way I could get your original error message was:
If the program is running:Gives the error message:
Also:
If the program is paused:Gives the error message:
I think the above two error messages are to be expected.
Cheers, Phill
PS You need to setp back to 0 after each time.
Which version are you using and could you post your xml and postgui_hal file
setp halui.program.stop 1
I also found that:
setp halui.program.run 1
Also:
in auto mode with the interpreter paused
Cheers, Phill
Last edit: 04 Feb 2019 04:42 by phillc54.
04 Feb 2019 05:38 - 04 Feb 2019 05:41 #125634
by Askjerry
Not sure how I would tie a SETP to a pyvcp button... let alone how to make it set then reset on a single button press.
The ZIP file for it all is attached... I'm writing it for a friend in Brazil... and he speaks Portuguese... you know... just to make the project more interesting...
The bottom two rows...
[ PROGRAM RUN ] [ LED INDICATOR ] [ PROGRAM STOP ]
[ PROGRAM PAUSE ] [ PROGRAM STEP ] [ PROGRAM RESUME ]
... I should really swap the RED and GREEN... hummm...
That is the layout...if that helps...
Last edit: 04 Feb 2019 05:41 by Askjerry.
Time to create page: 0.454 seconds
