PROGRAM STOP BUTTON - ERROR
04 Feb 2019 10:45 - 04 Feb 2019 10:46 #125650
by phillc54
Replied by phillc54 on topic PROGRAM STOP BUTTON - ERROR
Sorry, the setp commands were just to show you how I tested, I didn't mean for you to use them in your config.
The following xml and hal codes work as expected in both 2.7 and master.
As I said before, the only time I could duplicate your error was if I clicked RUN when the program was running.
You could prevent that by creating a disable pin for the run button so it was only enabled while the machine is idle.
Cheers, Phill
Warning: Spoiler!
<pyvcp>
<button>
<halpin>"run-b"</halpin>
<text>"Run"</text>
</button>
<button>
<halpin>"step-b"</halpin>
<text>"Step"</text>
</button>
<button>
<halpin>"pause-b"</halpin>
<text>"Pause"</text>
</button>
<button>
<halpin>"resume-b"</halpin>
<text>"Resume"</text>
</button>
<button>
<halpin>"stop-b"</halpin>
<text>"Stop"</text>
</button>
</pyvcp>
Warning: Spoiler!
net runner pyvcp.run-b halui.program.run
net stepper pyvcp.step-b halui.program.step halui.mode.auto
net pauser pyvcp.pause-b halui.program.pause
net resumer pyvcp.resume-b halui.program.resume
net stopper pyvcp.stop-b halui.program.stop
Cheers, Phill
Last edit: 04 Feb 2019 10:46 by phillc54.
- Thank you received: 5956
04 Feb 2019 16:51 #125669
Replied by tommylight on topic PROGRAM STOP BUTTON - ERROR
Hey Jerry, CAPS_LOCK stuck again ???
05 Feb 2019 04:23 #125717
by phillc54
Using your rener_custom_panel.xml and rener_postgui.hal I do not get any errors from the 'PARAR O PROGRAMA' button.
I was using the axis_mm sim config in LinuxCNC 2.7.14
Cheers, Phill
Askjerry wrote:
Now the stop button... it stops... but with an error...
Cheers, Phill
13 Feb 2019 16:31 #126352
If the button and pin are netted together then a press and release looks exactly like a setp 1 followed by a setp 0
Replied by andypugh on topic PROGRAM STOP BUTTON - ERROR
Not sure how I would tie a SETP to a pyvcp button... let alone how to make it set then reset on a single button press.
Time to create page: 0.174 seconds
