pyvcp pin does not exist
07 May 2019 20:18 #133087
by Buddy002
pyvcp pin does not exist was created by Buddy002
I had a problem which no longer remember so I formatted the hard drive and reloaded software. everything worked fine until it tried to load the right side panel then I got in the debug window panel_option.hal ;5;pin pyvcp.Clamp does not exist. So I commented out that line in the file and the debug file kicked the next pin in the list. I have looked at these files for multiple days with no result. I have included Tree.hal for the Tree milling machine which calls panel_options.hal Panel_options supplies panel.xml with the pin assignments for the panel
. If nothing is wrong with one of these files I could reload the system again.
07 May 2019 22:09 #133103
Replied by andypugh on topic pyvcp pin does not exist
Can we have the INI file too? That is what might be landing the panel code.
08 May 2019 12:38 #133134
by Buddy002
Replied by Buddy002 on topic pyvcp pin does not exist
Attached is the ini file
08 May 2019 15:05 #133150
Nothing immediately leaps out as being wrong.
Can I suggest that you load LinuxCNC from the command line (command "linuxcnc" and see if there is any sort of clue.
I suspect that PyVCP simply isn't loading. The terminal output might supply a clue.
Also add the command "show pin" to the top of the "panel_options.hal" file to get a list of all the pins that exist at that point to appear in the terminal output.
08 May 2019 20:42 #133191
by Buddy002
Another concern that I have is that I use mousepad as a text editor. I tried to install Gedit but my Syntacit program loader is pointed a website that no longer exists. I tried to change the target without success.
08 May 2019 21:47 #133200
Probably good that it failed. I once installed Gedit on Debian and it installed all of Gnome desktop.
If you can’t get on with Mousepad try Geany. (I currently use Geany everywhere)
10 May 2019 11:40 #133343
by Buddy002
show pin lists all the pins present
running linuxcnc from the command line results with a launch of the main panel no rightside panel and the final line reads " no option 'recent files in section ' DEFAULT':
I suppose Panel_options.hal should be listed in the DEFAULT section.
11 May 2019 16:50 #133457
by Buddy002
my current plan,
I ordered a new HD
I will load linuxcnc 2.6
Then I can upgrade to 2.7
According to Peter at Mesa 2.7 handles motion better.
I ordered a new HD
11 May 2019 18:02 - 11 May 2019 18:03 #133462
by Clive S
Why would you want to load 2.6 ? Save your config folder on a usb stick. then load 2.7 on the new drive then update it to 2.7.14
use one of the wizards to make a working system then edit the hal and ini file with the contents of your config folder from the usb stick.
Replied by Clive S on topic pyvcp pin does not exist
my current plan,
I ordered a new HD
Last edit: 11 May 2019 18:03 by Clive S.
12 May 2019 17:00 #133580
by pl7i92
Replied by pl7i92 on topic pyvcp pin does not exist
if you got a new HD
use the newest ISO
if you will like to be at the TOP
use USPACE 2.8 master
use the newest ISO
Time to create page: 0.189 seconds
