send var to pyvcp
09 Sep 2019 03:07 #144559
by sergiop
send var to pyvcp was created by sergiop
One question, I want to send the value of a variable # 20 to a pyvcp pin to show a number, how do I do ??
09 Sep 2019 08:41 #144574
by pl7i92
Replied by pl7i92 on topic send var to pyvcp
depending on system you are you can do this via a Mcode
or using a INI Var
You can output the value of a parameter from G-code to a motion.analog-out HAL pin, and show that in the PyVCP.
or using a INI Var
09 Sep 2019 09:59 #144584
by sergiop
Replied by sergiop on topic send var to pyvcp
I am making an engraving system and the idea is to see the serial number before executing the program (the serial number is stored in a variable)
09 Sep 2019 12:55 #144600
by pl7i92
as the serial number is to be engraved
you shoudt see it on the screen as gcode
09 Sep 2019 13:28 #144605
by sergiop
yes, but the surface to be engraved is irregular and it is difficult to see it from gcode
17 Sep 2019 00:19 #145354
Replied by andypugh on topic send var to pyvcp
You would need to send your G-code variable #20 out to HAL using M68
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m68
Then connect motion.analog-out-00 to the PyVCP input pin.
(G-code can (unreliably) read HAL values, but can't directly write to them.)
17 Sep 2019 17:16 #145411
by sergiop
but I have to send the values BEFORE executing the gcode, some method to read a variable and send the value to pyvcp without gcode ??
- Thank you received: 1370
17 Sep 2019 17:41 #145413
Replied by Todd Zuercher on topic send var to pyvcp
Maybe something like this would be better achieved using a filter script that reads your variable's value as the G-code is loaded and sets your pyvcp value then.
17 Sep 2019 18:26 #145423
How does #20 have any meaning before the G-code is executing?
17 Sep 2019 21:27 #145447
by sergiop
# 20 is the variable that stores the next number to write. I want to pass that value to pyvcp to visualize it before running the program.
Time to create page: 0.187 seconds
