send var to pyvcp
17 Sep 2019 21:45 #145450
Replied by andypugh on topic send var to pyvcp
Would an M0 pause command in the G-code be a solution?
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m0-m1
(press resume if good, stop if not)
18 Sep 2019 17:34 #145527
by nkp
Replied by nkp on topic send var to pyvcp
18 Sep 2019 18:01 #145528
I am not sure what your point is there? That panel is based on outputs from PyVCP to G-code (via motion.analog-in-NN pins) and was replaced by: forum.linuxcnc.org/41-guis/26550-lathe-macros?start=150#82743
I don't think that there is a way to read a G-code variable from the Python interface either, so GladeVCP isn't the answer.
www.bodgesoc.org/lathe/lathe.html
18 Sep 2019 18:20 #145535
by nkp
Sorry, I probably inattentively read the question ...
01 Nov 2019 08:01 #149338
by pl7i92
Replied by pl7i92 on topic send var to pyvcp
where does the VAR Value come from
it is somwhere generated
i woudt print it on generating and stop the Gcode M0 after Displaying it
user then decides
user then decides
Time to create page: 0.160 seconds
