Spindle RPM - Filter not working with encoder and 7i76
04 Jan 2020 22:19 #154034
by mooser
Spindle RPM - Filter not working with encoder and 7i76 was created by mooser
Doing a lathe conversion and only today realized there's no RPM readout in AXIS (not sure why that wouldn't be a standard kind of thing)
Anyway, found the pyVCP and read through the basics, copied the samples and create a bar-graph for my spindle RPM
Except it's not working
I've got a quad encoder hooked to TB3 and it's giving signals back (no index just quad) but when I look at the HAL meter for spindle-rpm-filtered there is no feedback at all (just spinning the encoder by hand)
If I change the meter to look at spindle-vel-fb-rps I get a result from the encoder (+/- both directions) as well as using spindle-revs (just a counter for location but shows the encoder is working)
Maybe the "filter" set too high and it can't see that I'm spinning the encoder but I can't find a filter value anywhere that looks related
M
M
04 Jan 2020 23:28 #154047
by mooser
Replied by mooser on topic Spindle RPM - Filter not working with encoder and 7i76
Update
Using the routine from PNCconf to add the RPM display I now get a value showing on the screen. I'm still trying to see what it changed and how it's different from what I did following the instructions on the pyVCP site but it's at least giving me something. Not the right thing and it's bouncing around quite a bit but at least it's a starting point
M
M
08 Jan 2020 22:21 #154355
Because it doesn't matter? It will either be what you commanded in the G-code, or vary with the CSS value.
What would you do differently if you could see the number?
Replied by andypugh on topic Spindle RPM - Filter not working with encoder and 7i76
08 Jan 2020 23:34 #154359
by mooser
LOL
Well for my poor old brain it's the indicator that I didn't punch in the correct speed in the first place
Almost embarrassing to tell you how many times I've been cutting away and look at the cut and go "that seems awfully slow/fast" and then check the rpm and go "oh, because it is slow/fast and I didn't change the speed in the program when I did whatever change"
M
M
08 Jan 2020 23:46 #154361
That's sort-of my point. The speed doesn't matter. it's too-fast / too-slow that matters.
08 Jan 2020 23:54 #154362
by mooser
It's only me that's slow
Here's what I picture happening to me. Just when I think I'm having a good day in the shop (hobby butcher remember)
It's running at 700 rpm for whatever dumb reason I have, I see it as too slow but I think I had it set at 1000 so I decide to bump it up to 1300...
Anyway I added the indicator (pyVCP widget) and although I haven't gotten to the actual turning on of the spindle yet (re the other thread on encoders and gear changes your helping me with) I'm hoping next weekend I should be able to connect the new control board on the desk here to the machine in the garage and get movement again
Thanks again
M
Thanks again
M
Time to create page: 0.167 seconds
