VMC related HAL questions.
31 Dec 2015 09:13 #67587
by thewho
Replied by thewho on topic VMC related HAL questions.
Yay, I can activate outputs from MDI
But I also noted that I need to home the spindle(?) because where it's at when I start linuxcnc is going to be 0 deg. And that is no problem unless someone (me) rotates the spindle by hand when the machine is turned off..
Any ideas?
Any ideas?
31 Dec 2015 14:52 #67595
Ah, yes, you have just reminded me of something else on my list of things to do when I get round to it.
I intend to add the spindle to the homing sequence.
sourceforge.net/p/emc/mailman/message/34441533/
What is required is to set the spindle-index-enable to true, then rotate the spindle until it goes false.
Until this is added to the homing sequence I think it will have to be done by cunning and guile.
The spindle-index-enable signal can be set true in the HAL file:(assuming that the spindle index enable signal is called spindle-index-enable)
You then need to ensure that the spindle rotates once through index to reset the encoder.
Adding a sequence of fixed direction moves to the toolchange G-code is probably the best way to do this.
Note that this won't necessarily work properly if the motion.spindle-orient-mode pin is not netted to the orient.0.mode pin. I forgot to do that in the sample HAL file.
Replied by andypugh on topic VMC related HAL questions.
Any ideas?
sets spindle-index-enable 1
O900 IF [<_tool_in_spindle> EQ 0]
M19 R180 P1
M19 R 0 P1
O900 ENDIF
02 Jan 2016 21:49 #67725
by thewho
It's working!
I finally learned the basics of hal and got the spindle orient routine to work really good. I had to limit the output so that I could get a fast response without excessive overshoot.
There is still work to be done in the subroutine but I'm really close to being satisfied with it
19 Jan 2016 17:49 #68772
by Jake
Replied by Jake on topic VMC related HAL questions.
Did anybody know who it was? I tried to search the user name and came up with nothing.
That is the same machine I have
23 Jan 2016 13:13 #68961
by thewho
What are you talking about Jake?
Today I'm running the first parts on the machine and found something that I have overlooked previously.
If tool in spindle is the required one it still does a toolchange.
I don't want to screw something up (did enough of that two days ago) so I'm asking before I try anything
Will this work?
Will this work?
IF [#<tool_in_spindle> EQ #<selected_tool>]
o<toolchange> endsub [1]
ENDIF
23 Jan 2016 13:30 #68963
by Jake
My post missed the quote the first time. That video is the same machine as mine. I tried to search his name but couldn't come up with anything. I'm curious how he approached getting the tool changer working on his.
Do you know who this is?
I think it is Awetmore
23 Jan 2016 13:42 #68965
You probably always want to do the tool retract, just so the approach move is always the same.
19 Dec 2016 03:43 - 19 Dec 2016 03:52 #84395
by Jake
Last edit: 19 Dec 2016 03:52 by Jake.
- Thank you received: 5926
19 Dec 2016 05:43 #84398
Replied by tommylight on topic VMC related HAL questions.
Well it is 5:42 AM here and i have not slept yet, but that sure looks like a dot.
Or am i missing something ?
19 Dec 2016 12:37 #84407
by Jake
resubscribing to the topic so it shows up in my topics. The new software flushed all that on me.
Time to create page: 0.154 seconds
