VMC related HAL questions.
04 Dec 2019 15:02 - 04 Dec 2019 15:03 #152000
by CNCDoc
Replied by CNCDoc on topic VMC related HAL questions.
It seems to work now. What makes 1 do the difference?
Last edit: 04 Dec 2019 15:03 by CNCDoc.
04 Dec 2019 16:11 #152005
Replied by andypugh on topic VMC related HAL questions.
There were two things. Your check was back to front (only run the tool changer if the system _is_ in preview) and the calling code was expecting a return value, so one needed to be added to the return command. (as is the case with the other return in the remap)
The following user(s) said Thank You: CNCDoc
09 Dec 2019 13:20 #152358
by CNCDoc
I load tool 1 to make Tool Touch Off. Then start the g code where tool 1 is used.
Starts a tool change sequence although the correct tool is already loaded.
Would this code fix it?
o998 IF [#<tool_in_spindle> = <selected_tool>]
o<toolchange> RETURN
o998 ENDIF
09 Dec 2019 15:54 #152368
That should work.
But should probably be
Return [1]
Return [1]
10 Dec 2019 09:21 - 10 Dec 2019 09:33 #152422
by CNCDoc
Is it possible to make a reset button for the tool change sequence?
It is very hand-applied when something is not working and the arm is under the spindle. Must restart linuxcnc etc
If it is possible to make a button that resets as the arm goes out, the locking pin up the carousel stops positioning (resets all signals that are set high by the tool swap sequence).
Edit:
Will it be a .ngc file resetting with M66 P3. On all P # used?
Edit:
Last edit: 10 Dec 2019 09:33 by CNCDoc.
13 Dec 2019 06:36 #152590
by CNCDoc
The code below seems to work:
o998 IF [#<tool_in_spindle> = <selected_tool>] o<toolchange> RETURN o998 ENDIF
o998 IF [#<tool_in_spindle> EQ #<selected_tool>]
o<toolchange> RETURN [1]
o998 ENDIF
07 Jan 2020 19:45 #154243
I think so, if you can code it as a G-code subroutine.
Look at the MDI_COMMAND INI file entry:
linuxcnc.org/docs/2.7/html/config/ini-co....html#_halui_section
Though it might suffice to just use MDI to:
O<toolchange_reset> CALL
Time to create page: 0.168 seconds
