Pokeys
10 Oct 2023 04:47 #282661
by dibor
Hello guys.
I am a new in LinuxCNC.
Here latest LinuxCNC version.
Trying to compile pokeyslib but got errors
What I should to do ?
Thank you.
PoKeysLibDevicePoKeys57Industrial.c: In function ‘PK57i_SearchDevice’:
PoKeysLibDevicePoKeys57Industrial.c:221:12: warning: implicit declaration of function ‘GetBroadcastAddresses’ [-Wimplicit-function-declaration]
addr = GetBroadcastAddresses();
PoKeysLibDevicePoKeys57Industrial.c:221:10: warning: assignment to ‘uint32_t *’ {aka ‘unsigned int *’} from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
PoKeysLibDevicePoKeys57Industrial.c:233:51: error: ‘SOCKADDR’ undeclared (first use in this function); did you mean ‘SOCK_RDM’?
if (sendto(txSocket, SendBuf, BufLen, 0, (SOCKADDR *)&remoteEP, sizeof(remoteEP)) == -1)
SOCK_RDM
PoKeysLibDevicePoKeys57Industrial.c:233:51: note: each undeclared identifier is reported only once for each function it appears in
PoKeysLibDevicePoKeys57Industrial.c:233:61: error: expected expression before ‘)’ token
PoKeysLibDevicePoKeys57Industrial.c:233:13: error: too few arguments to function ‘sendto’
In file included from PoKeysLibDevicePoKeys57Industrial.c:32:
/usr/include/x86_64-linux-gnu/sys/socket.h:152:16: note: declared here
extern ssize_t sendto (int __fd, const void *__buf, size_t __n,
make: *** [<builtin>: PoKeysLibDevicePoKeys57Industrial.o] Error 1
Thank you.
10 Oct 2023 11:20 #282682
by zarfld
i had the same proble some time ago, and i reported that to Matevz at polabs.
i got following answer:
Thank you for contacting me. The file PoKeysLibDevicePoKeys57Industrial.c was added in the last published version, but it was only used in a Windows environment. You can ommit this file during compile for now (remove it from the Makefile).
BR
Dominik
BR
Dominik
The following user(s) said Thank You: dibor
- Thank you received: 5957
12 Oct 2023 12:35 #282814
Replied by tommylight on topic Pokeys
Probably:
sudo halcompile --install pokeys.comp
12 Oct 2023 22:20 #282836
This does not give us anything useful to be able to help, what is the exact error you are getting, especially the "debug" section?I get error message when I run "loadusr pokeys"
16 Oct 2023 10:00 #283113
by dibor
I did exact all steps as shown on the page 10 "Updated Install Instructions"
All steps over without any error.
When I run loadusr pokeys I got error message in the terminal - loadusr command not found.
In other words I can not to include the driver to the HAL.
Thank U
Hi.
Thank U
Time to create page: 0.172 seconds
