output-15 startup error
26 Aug 2016 21:09 #79510
by WALLY434
output-15 startup error was created by WALLY434
Ive started trying to get this EMCO running and its getting there. while trying to start LinuxCNC, It says that hm2_5i25.0.7i76.0.0.output-15 does not exist. One of my buddies helping with this said it is most likely a syntax error and to figure out what output 15 does and that I might not even need it and to just turn it into a comment. I am getting confused with what could be wrong as it looks fine in the HAL. anything helps!
Thanks,
Wally
Thanks,
Wally
26 Aug 2016 21:16 #79511
Replied by andypugh on topic output-15 startup error
Output 15 is the first output mentioned in the HAL on the 7i76.
The most likely explanation is that there is no field-ppwer supplied to the 7i76, so the 7i76 internal logic is not active and the 7i76 GPIO has not been created.
26 Aug 2016 21:20 - 26 Aug 2016 21:21 #79512
by BigJohnT
Replied by BigJohnT on topic output-15 startup error
Comment out any offending lines so your config runs and while it is running open a terminal and say
This will give you a text file with a list of all the pins present and assuming you have field power you will get all the 7i76 pins too if not only the 5i25 pins will show up.
JT
halcmd show pin > pin.txt
JT
Last edit: 26 Aug 2016 21:21 by BigJohnT.
26 Aug 2016 21:41 - 26 Aug 2016 21:44 #79514
by WALLY434
Replied by WALLY434 on topic output-15 startup error
just tried to comment out that line and it still terminated with error
Last edit: 26 Aug 2016 21:44 by WALLY434. Reason: forgot to comment it out before trying again
26 Aug 2016 21:49 #79515
by BigJohnT
Same error or different?
Talking about this line changed from:
net machine-is-on hm2_5i25.0.7i76.0.0.output-15
to:
#net machine-is-on hm2_5i25.0.7i76.0.0.output-15
JT
to:
JT
26 Aug 2016 22:06 - 26 Aug 2016 22:16 #79516
by WALLY434
I changed the line to a comment exactly the same as your example and got the same error
the number at the end of the "does not exist" turns from a 3606 when I comment it out to a 3961 when I return it to original.
Last edit: 26 Aug 2016 22:16 by WALLY434.
26 Aug 2016 22:28 - 26 Aug 2016 22:29 #79518
by BigJohnT
Can you copy and paste the exact error and attach the changed hal file?
JT
JT
Last edit: 26 Aug 2016 22:29 by BigJohnT.
26 Aug 2016 22:38 #79520
I repeat: Do you have field-power connected to the 7i76?
27 Aug 2016 01:38 #79525
by WALLY434
no, I don't believe I do.
27 Aug 2016 01:40 - 27 Aug 2016 01:47 #79526
by WALLY434
Here is the entire error doc
Last edit: 27 Aug 2016 01:47 by WALLY434.
Time to create page: 0.319 seconds
