output-15 startup error
27 Aug 2016 01:51 #79527
Then that is the cause.
Replied by andypugh on topic output-15 startup error
no, I don't believe I do.
27 Aug 2016 17:07 #79561
by WALLY434
Replied by WALLY434 on topic output-15 startup error
now to figure out how to do this
27 Aug 2016 17:33 #79562
by WALLY434
I checked, The W2 is in the left hand position. The field power light is on (CR2) but the 5v light is not on (CR1).
27 Aug 2016 20:00 #79568
Replied by PCW on topic output-15 startup error
You need to set the 5I25/6i25 cable power jumpers to match the 7I76s 5V power source
So if you want to have the FPGA (5I25 or 6I25 in this case) card supply breakout board
(7I76 in this case) 5V you need to set the 5I25/6I25 jumpers to supply cable 5V
(5I25 or 6I25 W2 up)
Time to create page: 0.402 seconds
