is there driver for the new XHC-WHB04B-4
13 Dec 2017 19:38 #103089
by wolrah
Replied by wolrah on topic is there driver for the new XHC-WHB04B-4
I'm sorry, I could have phrased the question to be more clear.
Can I install your branch of 2.8 on top of the same Linux installation that is presently on the computer?
Asked another way;
Do I need to install a fresh copy of Linux RTAI and then download/build your branch?
Asked another way;
14 Dec 2017 06:07 #103099
by smalla
Replied by smalla on topic is there driver for the new XHC-WHB04B-4
You can download to a separate directory and compile there, and run from there or copy the binaries to your build. You can even merge with current branch as it can be done without errors, and should compile.
- Alex.Shamilich
15 Dec 2017 19:49 #103144
by Alex.Shamilich
Replied by Alex.Shamilich on topic is there driver for the new XHC-WHB04B-4
Hi Smalla!
I have WHB04B-6 to and trying to connect to my linuxcnc 2.7.11.
* I've cloned and compiled fork (github.com/smalla/linuxcnc) - without errors, all tests ok.
* connected usb receiver
* setup rules for /etc/udev/rules.d/90-whb04b.rules
* get working from /usr/bin/whb04b and get answers form controller* but when i'm trying to start LinuxCNC with config, and i'm getting duplicate component name ERROR:* HALFILE = whb04b.tcl - only once in whb04b-6.ini file
Please help
at@linuxcnc:~$ /usr/bin/whb04b
Creating pin: whb04b.x.pos-absolute
Creating pin: whb04b.jog.minus-c
whb04b: waiting for whb04b device
whb04b: found whb04b device
04 DF 00 00 0D 11 02 07 MPG delta +2
04 54 00 00 0D 11 00 04
04 B5 00 00 0D 11 FF 05 MPG delta -1
04 3D 00 00 0D 11 00 05
04 9D 0F 00 0D 11 00 16
04 87 00 00 0D 11 00 07
Found file(REL): ./core_sim9.hal
Found file(lib): /usr/share/linuxcnc/hallib/whb04b.tcl
HAL: ERROR: duplicate component name 'whb04b'
whb04b: ERROR: hal_init failed
whb04b.tcl: loadusr whb04b:
<waitpid failed whb04b whb04b
whb04b exited without becoming ready>
Is it plugged in?
Are permissions correct?
Continuing without whb04b
Failing cmd:
loadusr -W whb04b -I /usr/share/linuxcnc/hallib/whb04b-layout1.cfg -H -x -s 3
Please help
18 Dec 2017 09:30 #103277
by smalla
It will be a recursion in the configuration somehow, and it tries to load the module twice.
I will try to reproduce the error.
The following user(s) said Thank You: Alex.Shamilich
- Alex.Shamilich
19 Dec 2017 19:47 #103354
by Alex.Shamilich
Smalla, thanks for your reply
I' recompiled again and get working controller on 2.8.0 (LCD on controller works not correct - coordinates not changes)
May be i'm not correctly transfer compiled whb04b module from your fork to my production 2.7.11 ?
Which files i have to copy ?
1) All from config
2) ~/linuxcnc-dev/bin/whb04b
I'm not find whb04b_util.ko - only ~/linuxcnc-dev/rtlib/whb04b_util.so
1) All from config
20 Dec 2017 06:54 #103382
by smalla
Hi, it wont work with 2.7.xxx, only with 2.8.xxx. There is a whb04b.tcl file somewhere in the tree (search whb04b), that converts the joints and axes and build up the display. As 2.7 doesnt have joints, it would probably fail, You need to rewrite it for axes only.
there is no .ko file, as far as I remember.
23 Apr 2019 16:53 #131668
by careyer
Replied by careyer on topic is there driver for the new XHC-WHB04B-4
Hello everybody,
Hello smalla,
ordered a regular (old) HB04 from China and they shipped a WHB04B-4 instead. Even though I really like the layout of this unit it does not work with my LinuxCNC 2.7.11 - Is there any progress in getting this to work with 2.7?
Thank you very much for your kind help!
Cheers!
Thomas
Hello smalla,
Cheers!
Thomas
23 Apr 2019 18:00 #131676
by fixer
Replied by fixer on topic is there driver for the new XHC-WHB04B-4
if you scroll to the bottom of the page in this subforum you will find my python component for the new WHB. I use it on production machine for over one month now and haven't had any issues.
23 Apr 2019 18:47 - 23 Apr 2019 18:59 #131678
by careyer
Hello fixer,
thank you very much for your quick answer! Sorry.. but what page exactly should I scroll down to the bottom? Can you please gimme a hint/link? Thank you very much! Update: I suppose you refer to this: forum.linuxcnc.org/24-hal-components/361...4-4-python-component ?
How do I install it? Display still ain't working, right?
Cheers!
Cheers!
Last edit: 23 Apr 2019 18:59 by careyer.
02 May 2019 07:19 #132493
by smalla
My code should work with the WHB04B-4 with some USB ID changes in the code, but only with LinuCNC v 2.8.
Time to create page: 0.098 seconds
