Machine warning lights (Red, Amber, Green)
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
17 Jan 2017 21:53 #86011 by Todd Zuercher
Replied by Todd Zuercher on topic Machine warning lights (Red, Amber, Green)
Andy would win hands down. (he wrote the hardware interface driver for my first Linuxcnc machine, and helped walk me through setting it up.)
All I'm good for is the occasional bit of hal setup or ladder logic. A programmer I am not.
24 Sep 2023 09:00 #281540 by camb0
Replied by camb0 on topic Machine warning lights (Red, Amber, Green)
If anyone is following this thread I did it in HAL, it was actually quite easy, here's the config:
Put this in your main hal file
# Load classic ladder
loadrt classicladder_rt numPhysInputs=15 numPhysOutputs=15 numS32in=10 numS32out=10 numFloatIn=10 numFloatOut=10 numBits=50 numWords=50
addf classicladder.0.refresh servo-thread
# TODO switch back to this later loadusr classicladder --nogui custom.clp
loadusr classicladder custom.clp
Then in your post_gui (as you'll need some of the pins that load).
Note that pdnt pins are for my pendant the general lines are above but commented out:
########### SETUP THE MACHINE LIGHT #########
# Turn on the machine light to red to kick things off.
setp hm2_7i96s.0.7i76.0.1.output-12 true
net greenlight hm2_7i96s.0.7i76.0.1.output-10 classicladder.0.out-02
net yellowlight hm2_7i96s.0.7i76.0.1.output-11 classicladder.0.out-01
net redlight hm2_7i96s.0.7i76.0.1.output-12 classicladder.0.out-00
net e-stop halui.estop.is-activated classicladder.0.in-00
#net pwr-on halui.machine.is-on classicladder.0.in-01
net machine.is-on classicladder.0.in-01
#net prg-run halui.program.is-running classicladder.0.in-02
net pdnt.program-is-running halui.program.is-running classicladder.0.in-02
#net halui.program.is-idle classicladder.0.in-03
net pdnt.program-is-idle classicladder.0.in-03
The classic ladder file is attached.
File Name: custom.clp
File Size:5 KB
12 Oct 2024 08:01 - 12 Oct 2024 08:05 #311847 by cnctrucker
Replied by cnctrucker on topic Machine warning lights (Red, Amber, Green)
Deleted --
Last edit: 12 Oct 2024 08:05 by cnctrucker.
12 Oct 2024 08:07 - 12 Oct 2024 08:08 #311848 by cnctrucker
If you are not already using ClassicLadder, and don't want to bother adding it, it can all be done in hal as well.
I think I'd attack this something like this.
loadrt and2 count=2
loadrt xor2 count=1
loadrt siggen num_chan=1
addf and2.0 servo-thread
addf and2.1 servo-thread
addf xor2.0 servo-thread
addf siggen.0.update servo-thread
setp siggen.0.frequency 2
#Yellow Light
net yellow-in1 <= halui.machine.is-on => and2.0.in0
net yellow-in2 <= halui.program.is-idle => and2.0.in1
net yellow-out <= and2.0.out
net yellow-out => hm2_7i76e.0.7i76.0.0.output-01 #(or what ever your output pin is for the yellow light)
#Green Light
net green-in1 <= halui.program.is-running => xor2.0.in0
net green-in2 <= halui.program.is-paused => and2.1.in1
net flash <= siggen.0.clock => and2.1.in0
net green-flash <= and2.1.out => xor2.0.in1
net green-on <= xor2.0.out => hm2_7i76e.0.7i76.0.0.output-02
#Red Light
net red-on <= halui.estop.is-activated => hm2_7i76e.0.7i76.0.0.output-00 #(or what ever your output pin is for the red light)
(I just have a big red light on each of our machines that turns on when they are not running a program.)
I have a question which may be version related.  This line:
gives me the error:
/usr/share/linuxcnc/hallib/qtplasmac_comp.hal:21: Pin 'halui.machine.is-on' was already linked to signal 'yellow-in1'
when I try to run this in version 2.9.3
Could anyone give me some insight into why, and maybe a way to make it work?  I am a total newbie at HAL coding.
Last edit: 12 Oct 2024 08:08 by cnctrucker.
12 Oct 2024 08:16 #311850 by Aciera
Replied by Aciera on topic Machine warning lights (Red, Amber, Green)
The error appears because you are reassigning 'halui.machine.is-on' to a signal (even though it is the same one).
change:
to:
net yellow-in1 => and2.0.in0
12 Oct 2024 08:58 #311851 by cnctrucker
change:
to:
[code]net yellow-in1 => and2.0.in0
[/code]
Hmmm... my question would be is, how would I input the machine power state into the and2.0.in0 and the machine idle state into the and2.in1?
#Yellow Light net yellow-in1 <= halui.machine.is-on => and2.0.in0 # Checks that the machine is on
net yellow-in2 <= halui.program.is-idle => and2.0.in1 # Checks that the machine is idle
net yellow-out <= and2.0.out # Yellow light is either lit or not, depending on the machine idle state.
net yellow-out => parport.0.pin-17-out #(or what ever your output pin is for the yellow light)
Wouldn't I have to be able to get the signal from halui.machine.is-on and halui.program.is-idle into the and2 inputs to accomplish the desired output?
I would also be faced with a similar issue in the subsequent code block:
#Green Light net green-in1 <= halui.program.is-running => xor2.0.in0
net green-on <= xor2.0.out =>parport.0.pin-17-out
The intent in this block is that if the machine is running, the green light is solid; if the program is paused, then it is flashing.
Not sure I see the connections here with your suggestion -- could you maybe explain the logic a little?
12 Oct 2024 09:25 #311853 by Aciera
Please post your hal file so we are on the same page.
12 Oct 2024 15:38 #311879 by cnctrucker
As requested.  I have 5 status LEDs on the face of the control box; I am trying to light them to reflect the status of the machine.  The machine itself works perfectly -- it is the status light code that I am having trouble with.
# Generated by stepconf 1.1 at Tue Oct  8 18:45:41 2024
# overwritten when you run stepconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
loadrt hal_parport cfg="0xd010 out 0xb010 in"
setp parport.0.reset-time 2000
loadrt stepgen step_type=0,0,0,0
# Uncomment next 4 lines for classicladder version of machine lights in custom_postgui.hal
# loadrt classicladder_rt numPhysInputs=15 numPhysOutputs=15 numS32in=10 numS32out=10 numFloatIn=10 numFloatOut=10 numBits=50 numWords=50
# addf classicladder.0.refresh servo-thread
# loadusr classicladder --nogui custom.clp
# START CODE: Trying pure hal version of machine lights
loadrt and2 count=2
loadrt xor2 count=1
#Yellow Light
net yellow-out => parport.1.pin-16-out
#Green Light
net green-on <= xor2.0.out => parport.0.pin-17-out
#Red Light
net red-on <= halui.estop.is-activated => parport.0.pin-16-out
# END CODE: Trying pure hal version of machine lights
loadrt lut5
loadrt  plasmac
addf parport.1.read base-thread
addf parport.1.write base-thread
addf plasmac servo-thread
addf stepgen.update-freq servo-thread
# ---PLASMA INPUT DEBOUNCE---
loadrt dbounce names=db_breakaway,db_float,db_ohmic,db_arc-ok
addf db_float     servo-thread
addf db_ohmic     servo-thread
addf db_breakaway servo-thread
addf db_arc-ok    servo-thread
# ---JOINT ASSOCIATED WITH THE Z AXIS---
net plasmac:axis-position joint.3.pos-fb => plasmac.axis-z-position
# ---PLASMA INPUTS---
# ---all modes---
net plasmac:float-switch   => db_float.in
net plasmac:breakaway      => db_breakaway.in
net plasmac:ohmic-probe    => db_ohmic.in
net plasmac:ohmic-sense-in   => plasmac.ohmic-sense-in
# ---modes 0 & 1
net plasmac:arc-voltage-in => plasmac.arc-voltage-in
# ---modes 1 & 2
net plasmac:arc-ok-in      => db_arc-ok.in
# ---mode 2
net plasmac:move-up        => plasmac.move-up
net plasmac:move-down      => plasmac.move-down
# ---PLASMA OUTPUTS---
# ---all modes---
# net plasmac:ohmic-enable   <= plasmac.ohmic-enable
# net plasmac:scribe-arm     <= plasmac.scribe-arm
# net plasmac:scribe-on      <= plasmac.scribe-on
# ---ARC VOLTAGE ENCODER---
loadrt encoder num_chan=1
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
setp encoder.0.counter-mode 1
setp encoder.0.position-scale 1
net plasmac:arc-voltage-raw encoder.0.phase-A
net plasmac:arc-voltage-in encoder.0.velocity
net estop-out       => parport.0.pin-01-out
net xstep           => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir            => parport.0.pin-03-out
net ystep           => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net ydir            => parport.0.pin-05-out
net zstep           => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir            => parport.0.pin-07-out
net y2step          => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net y2dir           => parport.0.pin-09-out
setp parport.0.pin-14-out-invert 1
net plasmac:torch-on => parport.0.pin-14-out
net plasmac:arc-voltage-raw <= parport.0.pin-10-in
net plasmac:arc-ok-in <= parport.0.pin-11-in-not
net plasmac:float-switch <= parport.0.pin-12-in-not
net estop-ext       <= parport.0.pin-13-in
net min-home-x      <= parport.1.pin-02-in
net max-x           <= parport.1.pin-03-in
net min-home-y      <= parport.1.pin-04-in
net max-y           <= parport.1.pin-05-in
net min-home-z      <= parport.1.pin-06-in
net max-z           <= parport.1.pin-07-in
net min-home-y2      <= parport.1.pin-08-in
net max-y2           <= parport.1.pin-09-in
setp lut5.0.function 0x10000
net all-limit-home => lut5.0.in-4
net all-limit <= lut5.0.out
net xhoming <= joint.0.homing => lut5.0.in-0
net yhoming <= joint.1.homing => lut5.0.in-1
net y2homing <= joint.2.homing => lut5.0.in-2
net zhoming <= joint.3.homing => lut5.0.in-3
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 70000
setp stepgen.0.dirsetup 150000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
net min-home-x => joint.0.home-sw-in
net min-home-x => joint.0.neg-lim-sw-in
net max-x => joint.0.pos-lim-sw-in
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 70000
setp stepgen.1.dirsetup 150000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
net min-home-y => joint.1.home-sw-in
net min-home-y => joint.1.neg-lim-sw-in
net max-y => joint.1.pos-lim-sw-in
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 70000
setp stepgen.2.dirsetup 150000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net y2pos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net y2pos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net y2step <= stepgen.2.step
net y2dir <= stepgen.2.dir
net y2enable joint.2.amp-enable-out => stepgen.2.enable
net min-home-y2 => joint.2.home-sw-in
net min-home-y2 => joint.2.neg-lim-sw-in
net max-y2 => joint.2.pos-lim-sw-in
setp stepgen.3.position-scale [JOINT_3]SCALE
setp stepgen.3.steplen 1
setp stepgen.3.stepspace 0
setp stepgen.3.dirhold 70000
setp stepgen.3.dirsetup 150000
setp stepgen.3.maxaccel [JOINT_3]STEPGEN_MAXACCEL
net zpos-cmd joint.3.motor-pos-cmd => stepgen.3.position-cmd
net zpos-fb stepgen.3.position-fb => joint.3.motor-pos-fb
net zstep <= stepgen.3.step
net zdir <= stepgen.3.dir
net zenable joint.3.amp-enable-out => stepgen.3.enable
net min-home-z => joint.3.home-sw-in
net min-home-z => joint.3.neg-lim-sw-in
net max-z => joint.3.pos-lim-sw-in
net estop-ext => iocontrol.0.emc-enable-in
net tool-number <= iocontrol.0.tool-prep-number
net tool-change-loopback iocontrol.0.tool-change => iocontrol.0.tool-changed
13 Oct 2024 06:19 #311934 by Aciera
The conflict is between your halfile and 'hallib/qtplasmac_comp.hal':
Your halfile seems to get called first and 'halui.machine.is-on' is connected to the signal 'yellow-in1'. Then 'qtplasmac_comp.hal' is loaded and it wants to assign the same pin to a different signal which causes the error.
Open '/usr/share/linuxcnc/hallib/qtplasmac_comp.hal' and see which signal name it wants to connect 'halui.machine.is-on' to and use that signal in your halfile:
Change:
To:
net <signalname from qtplasmac_comp> => and2.0.in0
Time to create page: 0.323 seconds
