XHC-WHB04-4 Python component
10 Mar 2019 12:24 - 16 May 2020 13:01 #128225
by fixer
XHC-WHB04-4 Python component was created by fixer
EDIT 2020:
The driver and sample config is now availiable on github: github.com/MZot/whb04
-written in Python
-display now works
-display is refreshed only when data actually changes and when axis selector is not in "off "state This should preserve battery life and better comply with EMC rules (not sure).
-connects directly to LinuxCNC stat channel to read values
-shows workpiece coordinates on display
-automatically switches to manual mode when operated
-reset button sends abort() command to LinuxCNC
-macro1-macro10 buttons send MDI command with o-call to subroutines with axis selector and "fn" button state as parameters #1 and #2
Tested and works with LinuxCNC 2.7. I did not test with master.
-written in Python
-display now works
Last edit: 16 May 2020 13:01 by fixer.
The following user(s) said Thank You: nkp
10 Mar 2019 17:20 #128251
by pl7i92
Replied by pl7i92 on topic XHC-WHB04-4 Python component
Why dont you simple use the internal XHC component
i added my personel mashine
there is a image inside ANLEITUNG JPG that tells you the functions
23 Apr 2019 18:39 #131677
Is this component any good?
linuxcnc.org/docs/2.7/html/man/man9/lcd.9.html
(The answer is likely to be "maybe not" as it rather depends on sending one character per servo-thread, and your component runs in userspace rather than in a realtime thread)
Is there any chance that a common component could support bit XHC types?
Replied by andypugh on topic XHC-WHB04-4 Python component
LCD display does not work. I need some help there. If anyone knows how to send packets for strings on LCD, please tell. Some info about this is here: forum.planet-cnc.com/viewtopic.php?f=12&t=1125
23 Apr 2019 20:42 #131690
by fixer
XHC expects packet for string in some weird format, it shouldn't be hard to generate it, but I didn't bother with it.
Replied by fixer on topic XHC-WHB04-4 Python component
No. It is an usb transmission, it is also not realtime.Is this component any good?
Yes, this should be simple. Different devices have different usb PIDs. I would try to connect to the first one, if that fails the script should continue to try with the other PID.Is there any chance that a common component could support bit XHC types?
31 Aug 2019 07:43 #143708
by serafim
Replied by serafim on topic XHC-WHB04-4 Python component
Thanks for the script! I had to grant permitions to make it work.
Create file /etc/udev/rules.d/99-my.rules and add a line in it:
SUBSYSTEM=="usb", ATTR{idVendor}=="10ce", ATTR{idProduct}=="eb93", MODE="666"
Reload udev with "sudo udevadm trigger" and unplug/plug adapter.
31 Aug 2019 07:51 - 31 Aug 2019 07:54 #143711
by pl7i92
her is my main hal for the xhc i use on lots of mashines 4plasmas
the coresponding INI
loadusr -W xhc-hb04 -I mars_xyz_xhc.ini -H -s 4
#loadusr -W xhc-hb04 -H -I wbcnc_2.7.9.ini -s 4
loadrt flipflop names=flipflop_resume,flipflop_pause,flipflop_run,flipflop_icon
addf flipflop_resume servo-thread
addf flipflop_pause servo-thread
addf flipflop_run servo-thread
addf flipflop_icon servo-thread
# RESET/ESTOP button
loadrt multiclick names=click_estop,click_macro1,click_zero,click_spindel,click_stop,click_mode,click_macro2,click_macro3,click_probe_z
addf click_estop servo-thread
addf click_mode servo-thread
addf click_macro2 servo-thread
addf click_probe_z servo-thread
#click_probe_z in postgui
net xhc-macro2 xhc-hb04.button-macro-2 => click_macro2.in
net xhc-mode xhc-hb04.button-mode => click_mode.in
net estop-xhbutton xhc-hb04.button-reset => click_estop.in
net estop-activated halui.estop.activate <= click_estop.single-click
net estop-reset halui.estop.reset <= click_estop.double-click
# Home button
addf click_macro3 servo-thread
net xhc-macro3 xhc-hb04.button-macro-3 => click_macro3.in
net home halui.home-all <= click_macro3.double-click
# maschine on/off
addf click_macro1 servo-thread
net maschine-on-off-xhbutton xhc-hb04.button-macro-1 => click_macro1.in
net joy-mashine-off halui.machine.off <= click_macro1.single-click
net joy-mashine-on halui.machine.on <= click_macro1.double-click
# Program control
addf click_stop servo-thread
net button-stop xhc-hb04.button-stop => click_stop.in
net stop-prog-run halui.program.stop <= click_stop.single-click
net set-prog-to-start click_stop.double-click => halui.mdi-command-12
net button-start-pause xhc-hb04.button-start-pause => flipflop_pause.clk flipflop_resume.clk flipflop_run.clk
net is-paused halui.program.is-paused => flipflop_resume.data flipflop_pause.reset
net is-running halui.program.is-running => flipflop_pause.data flipflop_run.reset flipflop_resume.reset
net is-idle halui.program.is-idle => flipflop_run.data
net resume flipflop_resume.out => halui.program.resume
net pause flipflop_pause.out => halui.program.pause
net run flipflop_run.out => halui.mode.auto halui.program.run
net step xhc-hb04.button-rewind => halui.program.step
# Absolute position LCD
net pos-x halui.axis.0.pos-feedback => xhc-hb04.x.pos-relative
net pos-y halui.axis.1.pos-feedback => xhc-hb04.y.pos-relative
net pos-z halui.axis.2.pos-feedback => xhc-hb04.z.pos-relative
net pos-a halui.axis.3.pos-feedback => xhc-hb04.a.pos-absolute
# Relative position LCD
net pos-rel-x halui.axis.0.pos-relative => xhc-hb04.x.pos-absolute
net pos-rel-y halui.axis.1.pos-relative => xhc-hb04.y.pos-absolute
net pos-rel-z halui.axis.2.pos-relative => xhc-hb04.z.pos-absolute
net pos-rel-a halui.axis.3.pos-relative => xhc-hb04.a.pos-relative
# jog Speed
loadrt mux8 count=2
addf mux8.0 servo-thread
addf mux8.1 servo-thread
#wheel speed per tick
setp mux8.0.in0 0
setp mux8.0.in1 0.1
setp mux8.0.in2 0.5
setp mux8.0.in3 0
setp mux8.0.in4 1
#speed for moving axes
setp mux8.1.in0 0 # this one must be 0 to prevent motion unless a button is pressed
setp mux8.1.in1 250
setp mux8.1.in2 1000
setp mux8.1.in3 0
setp mux8.1.in4 2500
# step logic
loadrt updown count=1
addf updown.0 servo-thread
setp updown.0.wrap true
setp updown.0.min 0
setp updown.0.max 6
net stepcount updown.0.countup <= xhc-hb04.button-step => xhc-hb04.stepsize-up
#reset step to zero
net updownreset updown.0.reset <= click_mode.single-click
#convert count s32 to float
loadrt conv_s32_float count=1
addf conv-s32-float.0 servo-thread
net conv-step conv-s32-float.0.in updown.0.count
#step signal compare
loadrt comp count=7
addf comp.0 servo-thread
addf comp.1 servo-thread
addf comp.2 servo-thread
addf comp.3 servo-thread
addf comp.4 servo-thread
addf comp.5 servo-thread
addf comp.6 servo-thread
setp comp.0.in0 0
setp comp.1.in0 1
setp comp.2.in0 2
setp comp.3.in0 3
setp comp.4.in0 4
setp comp.5.in0 5
setp comp.6.in0 6
loadrt or2 count=5
addf or2.0 servo-thread
addf or2.1 servo-thread
addf or2.2 servo-thread
addf or2.3 servo-thread
addf or2.4 servo-thread
net stepcounter-out conv-s32-float.0.out => comp.0.in1 comp.1.in1 comp.2.in1 comp.3.in1 comp.4.in1 comp.5.in1 comp.6.in1
#jog scale selector from step to mux
net scale-selectorA mux8.0.sel0 <= comp.1.equal => or2.0.in0
net scale-selectorB mux8.0.sel1 <= comp.2.equal => or2.0.in1
net scale-selectorC mux8.0.sel2 <= comp.3.equal => or2.1.in0
net led-wheel-sectorA or2.1.in1 <= or2.0.out
# postgui net pyvc-led-wheel or2.1.out => pyvcp.wheel_select
net jog-scale mux8.0.out => axis.0.jog-scale axis.1.jog-scale axis.2.jog-scale axis.3.jog-scale
net joy-speed-1 mux8.1.sel0 <= comp.4.equal => or2.2.in0
net joy-speed-2 mux8.1.sel1 <= comp.5.equal => or2.2.in1
net joy-speed-3 mux8.1.sel2 <= comp.6.equal => or2.3.in0
net led-button-sectorA or2.3.in1 <= or2.2.out
# postgui net pyvc-led-button or2.3.out => pyvcp.button_select
net joy-speed-final halui.jog-speed <= mux8.1.out
#logic for Button velomotion
loadrt and2 count=12
addf and2.0 servo-thread #Jog positiv X
addf and2.1 servo-thread
addf and2.2 servo-thread
addf and2.3 servo-thread #jog negativ X
addf and2.4 servo-thread
addf and2.5 servo-thread
addf and2.6 servo-thread # Zeroing X
addf and2.7 servo-thread
addf and2.8 servo-thread
addf and2.9 servo-thread #a plus
addf and2.10 servo-thread #a minus
addf and2.11 servo-thread #azero
# Jog wheel and axis selection button
net jog-x axis.0.jog-enable <= xhc-hb04.jog.enable-x => and2.0.in0 and2.3.in0 and2.6.in0
net jog-y axis.1.jog-enable <= xhc-hb04.jog.enable-y => and2.1.in0 and2.4.in0 and2.7.in0
net jog-z axis.2.jog-enable <= xhc-hb04.jog.enable-z => and2.2.in0 and2.5.in0 and2.8.in0
net jog-a axis.3.jog-enable <= xhc-hb04.jog.enable-a and2.9.in0 and2.10.in0 and2.11.in0
net joy-pos xhc-hb04.button-macro-7 and2.3.in1 and2.4.in1 and2.5.in1 and2.9.in1
net joy-neg xhc-hb04.button-macro-6 => and2.0.in1 and2.1.in1 and2.2.in1 and2.10.in1
net jog-counts xhc-hb04.jog.counts => axis.0.jog-counts axis.1.jog-counts
net jog-counts-neg xhc-hb04.jog.counts-neg => axis.2.jog-counts
#net jog-speed halui.jog-speed <= halui.max-velocity.value
net joy-xpos-jog halui.jog.0.plus <= and2.3.out
net joy-xneg-jog halui.jog.0.minus <= and2.0.out
net joy-ypos-jog halui.jog.1.plus <= and2.4.out
net joy-yneg-jog halui.jog.1.minus <= and2.1.out
net joy-zpos-jog halui.jog.2.plus <= and2.5.out
net joy-zneg-jog halui.jog.2.minus <= and2.2.out
net joy-apos-jog halui.jog.3.plus <= and2.9.out
net joy-aneg-jog halui.jog.3.minus <= and2.10.out
# Wheel for feedrate and spindle
setp halui.feed-override.scale 0.1
net jog-counts => halui.feed-override.counts
net jog-feed halui.feed-override.count-enable <= xhc-hb04.jog.enable-feed-override
net jog-feed2 halui.feed-override.value => xhc-hb04.feed-override
setp halui.spindle-override.scale 0.01
net jog-counts => halui.spindle-override.counts
net jog-spindle halui.spindle-override.count-enable <= xhc-hb04.jog.enable-spindle-override
net jog-spindle2 halui.spindle-override.value => xhc-hb04.spindle-override
net spindle-rps motion.spindle-speed-cmd-rps => xhc-hb04.spindle-rps
#buttons
#net reset-jog updown.0.reset <= click_mode.single-click
net goto-partzero xhc-hb04.button-goto-zero => halui.mdi-command-03
net park halui.mdi-command-04 <= xhc-hb04.button-home
net safe-z halui.mdi-command-05 xhc-hb04.button-safe-z
# X=0, Y=0, Z=0 XYZ=0
addf click_zero servo-thread
net xh-button-zero xhc-hb04.button-zero => click_zero.in
net zerobutton-single-click click_zero.single-click => and2.6.in1 and2.7.in1 and2.8.in1 and2.11.in1
net zerobutton-double-click click_zero.double-click => halui.mdi-command-06
net x0 halui.mdi-command-00 and2.6.out
net y0 halui.mdi-command-01 and2.7.out
net z0 halui.mdi-command-02 and2.8.out
#net a0 halui.mdi-command-02 and2.11.out
# halfzero
net halfzero-x halui.mdi-command-07 <= xhc-hb04.button-half-x
net halfzero-y halui.mdi-command-08 <= xhc-hb04.button-half-y
#plasma torch
addf click_spindel servo-thread
net xh-button-spindel xhc-hb04.button-spindle => click_spindel.in
net plasma-off halui.mdi-command-09 <= click_spindel.single-click
net plasma-on halui.mdi-command-10 <= click_spindel.double-click
net plasma-thc-on halui.mdi-command-11 <= click_spindel.triple-click
#load gcode by double click the macro2
net xhloadfile click_macro2.double-click => halui.mdi-command-13
#test icons
#net is-running => xhc-hb04.icon-cycle
#net test-icon xhc-hb04.button-macro-7 => xhc-hb04.hb-mode
#net home-icon halui.joint.0.is-homed xhc-hb04.icon-ref
#net in-position => xhc-hb04.icon-pos
# this needs to be set in postgui file
#net reseterror click_mode.double-click => axisui.notifications-clear
[XHC-HB04]
BUTTON=17:button-reset
BUTTON=16:button-stop
BUTTON=01:button-goto-zero
BUTTON=02:button-start-pause
BUTTON=03:button-rewind
BUTTON=04:button-probe-z
BUTTON=0C:button-spindle
BUTTON=06:button-half
BUTTON=07:button-zero
BUTTON=08:button-safe-z
BUTTON=09:button-home
BUTTON=0A:button-macro-1
BUTTON=0B:button-macro-2
BUTTON=05:button-macro-3
BUTTON=0F:button-macro-6
BUTTON=10:button-macro-7
BUTTON=0D:button-step
BUTTON=0E:button-mode
[HAL]
HALUI = halui
HALFILE = mars_xyz_xhc.hal
HALFILE = custom.hal
HALFILE = xhc-hb04.hal
POSTGUI_HALFILE = custom_postgui_hb04.hal
[HALUI]
# HalUI-MDI-Befehle hier einfügen (max. 64) erste =MDI 0
MDI_COMMAND=G10 L20 P1 X0
MDI_COMMAND=G10 L20 P1 Y0
MDI_COMMAND=G10 L20 P1 Z0
MDI_COMMAND=G0 G54 X0 Y0 Z25
MDI_COMMAND=G0 G53 X50 Y460 Z-25
MDI_COMMAND=G0 G53 Z-25
MDI_COMMAND=G10 L20 P1 X0 Y0 Z0
MDI_COMMAND=o<halfx> call
MDI_COMMAND=o<halfy> call
MDI_COMMAND= M5
MDI_COMMAND=S100 M3
MDI_COMMAND= M5
MDI_COMMAND= M5
MDI_COMMAND= M5
MDI_COMMAND = o<znullen> call
MDI_COMMAND = G10 L20 P1 X 0.0 M100
MDI_COMMAND = G10 L20 P1 Y 0.0 M100
MDI_COMMAND = G10 L20 P1 X0.0 Y0.0 M100
MDI_COMMAND = G54 G1 X0.0 Y0.0 F2000
MDI_COMMAND = G53 G1 X50.0 Y460.0 Z-10 F800
MDI_COMMAND = M5
Last edit: 31 Aug 2019 07:54 by pl7i92. Reason: more info
31 Aug 2019 08:17 #143713
by serafim
Thanks, pl7i92. Can you or somebody share hal for the WHB04B? I can see that designated pins work but drives are not moving. I guess I'm missing some pin connection.
loadusr -W whb04b
net axis0jogenable axis.x.jog-enable whb04b.sel_x
net axis1jogenable axis.y.jog-enable whb04b.sel_y
net axis2jogenable axis.z.jog-enable whb04b.sel_z
net joginc whb04b.inc
net joginc axis.x.jog-scale
net joginc axis.y.jog-scale
net joginc axis.z.jog-scale
net jogcnts whb04b.mpg_cnt
net jogcnts axis.x.jog-counts
net jogcnts axis.y.jog-counts
net jogcnts axis.z.jog-counts
setp axis.x.jog-vel-mode 1
setp axis.y.jog-vel-mode 1
setp axis.z.jog-vel-mode 1
31 Aug 2019 14:46 #143727
by pl7i92
this is only the base connection
So do you got a COMP called whb04b
otherwise use the internal for the base XHC it will work for all pins
its alot more to be connected to run the B version
WHERE are the BUTTONS Discribed INI file
linuxcnc.org/docs/html/man/man1/xhc-hb04.1.html
you need to understand how the postgui system workes together with HALUI
Get signal from external and do somthing in the servo tread time
16 May 2020 13:06 #167967
by fixer
I edited fist post, component is now on github.
It does behave a bit different, it produces much less traffic on the USB bus than the "official" driver.
25 Jan 2021 19:49 #196547
by probotix
Replied by probotix on topic XHC-WHB04-4 Python component
Good job on this. I have it running on 2.8.1
Can you explain this syntax for me?
Also, when running inches, the 1.0 jog increments only moves 0.48 inches. Any ideas?
h.fn = data[2] == 12 or data[3] == 12
Time to create page: 0.167 seconds
