Physical Feed override knob
03 Apr 2019 20:49 #130233
by Erikcnc
I got the potentiometer to 24vdc. Its reading the values if I turn it.
But sadly no response in gmoccapy.
Replied by Erikcnc on topic Physical Feed override knob
To get a higher reading (and more resolution), you should connect the potentiometer to field power (12 or 24VDC)
03 Apr 2019 21:08 #130235
Replied by PCW on topic Physical Feed override knob
Sorry I was thinking the ~24 was in counts but forgot that the default input scaling was in volts (and 24V is about 2/3 of full scale so resolution is about 1 part in 180, good enough for feed override)
You undoubtedly need some more hal plumbing before the feed over-ride pot will actually work...
03 Apr 2019 23:14 #130243
Does halmeter show the gmoccapy input pin changing value as you turn the knob?
Replied by andypugh on topic Physical Feed override knob
04 Apr 2019 06:35 #130263
by pl7i92
Replied by pl7i92 on topic Physical Feed override knob
can you show us your postgui File
to see the scale and connection
04 Apr 2019 08:16 #130272
by Erikcnc
Quick answer. No it does not.
04 Apr 2019 12:08 #130278
I suspect, then, that you haven't made the HAL connection or have made it in a HAL file that is not being loaded by the config.
The following user(s) said Thank You: Erikcnc
05 Apr 2019 17:30 #130358
by Erikcnc
So, do i have to place it in a different hal file?
05 Apr 2019 18:15 #130362
Hard to say with no information at all.
What do have now, and where?
05 Apr 2019 20:25 #130363
by Erikcnc
I got it now in the, let's say, in the standard hal file.
Only one line.
Net gmoccapy.feed.feed-override.direct-value => hm2_7i76e.0.7i76.0.0.analogin0
Only one line.
05 Apr 2019 20:45 - 05 Apr 2019 20:46 #130365
Ah! That creates a new "signal" called "gmoccapy.feed.feed-override.direct-value".
The format of a "net" statement is
try
net signal-name pin2 (pin2....)
try
net feed-override-direct gmoccapy.feed.feed-override.direct-value <= hm2_7i76e.0.7i76.0.0.analogin0
Last edit: 05 Apr 2019 20:46 by andypugh.
Time to create page: 0.129 seconds
