Physical Feed override knob
08 Apr 2019 13:20 #130505
by OT-CNC
I'm sure you can and it works. My point that I was trying to make is, as an example say, your pot is set at 50% and you move your slider in the gui to 100% the pot is still at 50% in it's physical position and not at 100%. They will be mismatched.
Replied by OT-CNC on topic Physical Feed override knob
Hi OT-CNC
I can see in gmoccapy all trhre values I set via pots in realtime.
Mike
- Mike_Eitel
- Thank you received: 185
10 Apr 2019 06:08 #130587
by Mike_Eitel
Replied by Mike_Eitel on topic Physical Feed override knob
Nop
If I draw my pot-button the view in gmoccappy changes and also slider plus digital value changes according pot position.
Mike
Mike
21 Sep 2019 20:27 #145789
by Erikcnc
Replied by Erikcnc on topic Physical Feed override knob
Hi All,
So i am was trying to copy - paste the feed override script to my other machine that uses the same board.
Only thing is i got this error says scale already exist.
Also, i see in hall show that the analog input is called input-00 instead of analogin0.
this pin is also not float value.
mean while i am also setting up a mpg with 2 switches for counts and X and Z.
not working either.
mpg is based on this. changed the inputs for my mesa 7i76e
mpg example
base-thread also does not exist ...
any one got a clue?
not working either.
mpg example
any one got a clue?
21 Sep 2019 21:17 - 21 Sep 2019 21:17 #145791
Replied by PCW on topic Physical Feed override knob
7I76E analog inputs have these names:
hm2_7i76e.0.7i76.0.0.analogin0
hm2_7i76e.0.7i76.0.0.analogin1
hm2_7i76e.0.7i76.0.0.analogin2
hm2_7i76e.0.7i76.0.0.analogin3
You will need to include "sserial_port_0=20xxxxxx" in the config=" blah blah blah"
section of the hal file to enable the analog inputs (and the MPG encoder inputs)
The MPG example you show is for a parallel port, when using the 7I76E MPG inputs
you do not used the encoder component or the base thread, but rather use the MPG
encoder counts directly from the 7I76E:
hm2_7i76e.0.7i76.0.0.enc0.count
(first MPG counter)
hm2_7i76e.0.7i76.0.0.enc1.count
(second MPG counter)
(first MPG counter)
Last edit: 21 Sep 2019 21:17 by PCW.
The following user(s) said Thank You: Erikcnc
22 Sep 2019 09:17 - 22 Sep 2019 09:18 #145830
by Erikcnc
thanks for the reply.
offcourse.....the serial, forgot about that. i changed it.
for now i removed the mpg stuff to get the feedrate knob to work first.
i get a weird debug, still the same.
Debug file information:
Note: Using POSIX realtime
11:07:33.809 WARNING Config: mousetweaks GSettings schema not found, mousetweaks integration disabled.
(gmoccapy:1495): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion 'lm->priv->ids == NULL' failed
scale: already exists
postgui_call_list.hal:5: waitpid failed /usr/bin/rtapi_app scale
postgui_call_list.hal:5: /usr/bin/rtapi_app exited without becoming ready
postgui_call_list.hal:5: insmod for scale failed, returned -1
(onboard:1505): Gdk-CRITICAL **: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
1444
PID TTY STAT TIME COMMAND
1492
Stopping realtime threads
Unloading hal components
Last edit: 22 Sep 2019 09:18 by Erikcnc.
22 Sep 2019 13:37 #145840
by Erikcnc
okay this is weird,
i tried to build it up without the scale to find if its working.
this does not exist...
setp gmoccapy.analog-enable 1
22 Sep 2019 13:37 #145841
Looks like you are trying to "loadrt scale" twice.
That will not work, if you need more scale components, you need to
specify how many to instantiate (either by number or by multiple names)
in a single loadrt line
man scale
man scale
22 Sep 2019 13:44 #145842
by Erikcnc
thats what i thought. thats clears it up more.
do you got a example how it should look like for a second scale line?
22 Sep 2019 14:38 - 24 Sep 2019 17:55 #145849
by Erikcnc
got it!!
in main hal file i got
and in my postgui_call_list.hal
gmoccapy.analog-enable does not exist, but instead it is gmoccapy.feed-override.analog-enable
loadrt scale names=scale.spindle,scale.feed
addf scale.feed servo-thread
setp scale.feed.gain 0.0417
net feed-override-raw hm2_7i76e.0.7i76.0.0.analogin0 => scale.feed.in
net feed-override-scaled scale.feed.out => gmoccapy.feed-override.direct-value
setp gmoccapy.feed-override.analog-enable 1
Last edit: 24 Sep 2019 17:55 by Erikcnc.
02 Sep 2020 02:28 - 02 Sep 2020 02:29 #180383
by keyboard
Replied by keyboard on topic Physical Feed override knob
How would i need to modify the above HAL lines to get it to work in QTPyvcp ? I'm using the QTdragon GUI. I have connected a 10k pot to Analog0 on a MESA7i76E. Mode =1.
Do I just takeout the gmoccapy ? I want to use the pot to control feedrate .
Thanks.
Thanks.
Last edit: 02 Sep 2020 02:29 by keyboard.
Time to create page: 0.108 seconds
