5Axis Kinetic from 2.8 on 2.7x
What does the message say?This does not work, an error message appears when starting linux.
As rod said, you might want to upgrade to 2.8. You have to set your repository:
buildbot.linuxcnc.org/
Or, download a new image if you want:
forum.linuxcnc.org/9-installing-linuxcnc...ver-mint-iso?start=0
Be aware though that you will have to adjust your configuration for version 2.8 because of the distinction between joints and axis.
linuxcnc.org/docs/2.8/html/getting-start...tion_files_for_2_8_x
Probably basic question ...
Can I do 5 axes simultaneously with the linuxCNC 2.7.14 version? Or do I have to go through version 2.8?
I am having too much trouble updating my CNC control computer.
It is under Dabian GNU. the "Update" / "Upgrate" no longer want to be done.
Thank you for your help
- Thank you received: 5946
what should I put in should I change in my .hal & .ini files?
Thank you
You might want to have a look at the switchkins branch as it allows you to switch between trivial kinematics to tcp kinematics. This requires a run in place installation though.
www.panix.com/~dgarrett/stuff/switchkins.html
Hello Aciera,
- I understood that the mixture of the two versions was not compatible (post from Rodw).
- it is clear that if I want to do (TCP) I have to go through the "xyzac-trt-kins" module which is only available in version 2.8.
- My problem is that my CNC control computer is 32 bit, so I can only install a 32 bit "OS" and find LinuxCNC 2.8 32bits.
- My Dabian GNU system refuses updates. The links are no longer active.
- Do you know a procedure to reinstall my 32 bit system with LinuxCNC 2.7.14 and then an update with a file (no network) to LinuxCNC 2.8.
I read, that during the update, when starting LinuxCNC 2.8 for the first time the migration was automatic, Linuxcnc 2.8 converted the .hal .ini files from 2.7 to 2.8 and many other things.
- Thank you again for following my misadventures, and for answering all my questions.
But I think the program is superb, I was able to machine some parts in 5 axes and I realized the reliability and precision of the system, it is for this reason that I want to go further.
- In addition the community is great, is available, this is how we move forward and when I have fully developed my machine, I will upload all my "config" files to help like me today people who want to succeed in their projects.
Thank you
I gather there is a converter to migrate your config from 2.7 to 2.8. I have never used it though.I read, that during the update, when starting LinuxCNC 2.8 for the first time the migration was automatic, Linuxcnc 2.8 converted the .hal .ini files from 2.7 to 2.8 and many other things.
As to upgrading:
Have you added the repositories to your synaptic package manager as described in the buildbot webpage?
Not sure if there is a way to download the necessary files and copy them to your machine.
Maybe start a new thread about where to find a 32bit ISO with version2.8 that is suitable for parallel port operation. My systems use the Ethernet port and for that latency is less crucial. Also my hardware is 64bit
- I have an i5 PC running Mint 19.2, with a "linuxCNC 2.9.0 pre0-925-g5e11c1db" version that I don't use because I don't have a parallel port. However, it has an Ethernet connection.
-Can I use this PC to control my machine with an Ethernet port?
- If Yes, then I go to another World. I have no idea of the configuration and the communication equipment needed between my PC and my Break out card?
Please can you tell me more ?
Regards
Yes there is and it does a pretty good job at it, but if there are a lot of edited stuff in the ini and hal file there might be a need to do some more editing. For standard configs it always worked.I gather there is a converter to migrate your config from 2.7 to 2.8. I have never used it though.
