Closing the servo loop with HAL mesa 7i76
10 Jan 2020 16:22 #154557
by Clive S
Ok I can verify that 1 turn on the shaft is 5mm on the DRO and encoder position also shows 5 with both going +ve
I have noticed that when using a feed rate of 1000mm/min then encoder velocity pin shows about 16.8 and half that with a feed rate of 500mm/min.
I am still getting following errors if I used above about 1000mm/min in open loop with P = 1000
Replied by Clive S on topic Closing the servo loop with HAL mesa 7i76
Yes
You should also be able to check the scale by commanding one turn worth of motion (say 5mm for 5mm pitch ballscrew) and verifying that the motor makes 1 turn. If this works, command 10 or 100 turns worth of motion and verify the the motor shaft ends up in the same place...
10 Jan 2020 16:38 #154559
Replied by PCW on topic Closing the servo loop with HAL mesa 7i76
MIN_FERROR = 1.0
MAX_VELOCITY = 35
MAX_ACCELERATION = 500
^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Note the comment
STEPGEN_MAXVEL = 31.25
STEPGEN_MAXACCEL = 600
MAX_VELOCITY = 35
10 Jan 2020 17:13 - 10 Jan 2020 17:14 #154560
by Clive S
Thank you I could not see the wood for the trees.
I have changed them to 43.75 and 625
Now I can get the the feed rate up to 2500mm/min it errors at about 2800mm/min
this is with closed loop and P10
Is this relevant "I have noticed that when using a feed rate of 1000mm/min then encoder velocity pin shows about 16.8 and half that with a feed rate of 500mm/min."
MIN_FERROR = 1.0
MAX_VELOCITY = 35
Last edit: 10 Jan 2020 17:14 by Clive S.
10 Jan 2020 18:18 - 10 Jan 2020 18:19 #154566
16.8 is about correct (1000 mm/m = 16.666 mm/s)
43.75 mm/s = 2625 mm/m so 2800 mm/m is not reachable with that stepgen velocity limit
Last edit: 10 Jan 2020 18:19 by PCW.
10 Jan 2020 19:03 #154568
by Clive S
Ok Thanks
I have upped the stepgen to 100. I have a bit of oscillation of the third digit which of the P terms do I need to adjust ?
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10
MIN_FERROR = 1.0
MAX_VELOCITY = 100
STEPGEN_MAXVEL = 125
STEPGEN_MAXACCEL = 625
P = 10.0
I = 0.01
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
ENCODER_SCALE = -2000
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10
MIN_FERROR = 1.0
MAX_VELOCITY = 100
P = 10.0
I = 0.01
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
10 Jan 2020 19:28 #154569
if the error is in the 1-2 encoder count range it may be normal dithering
You can reduce this with a small amount of deadband (say .001 mm)
11 Jan 2020 19:11 #154631
by Clive S
I am still struggling with this. This is my first time with a servo and not sure what to set the follow to
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 2000 ENCODER_SCALE = -2000
I am getting an error " hm2/hms_5i25.0: stepgen.00.maxvel is too big for current step timings & position-scale, clipping to max possible
what do I need to adjust for this.
I would like to get 20mtr/min The servo rotates 1 rev when commanded 5mm the encoder position pin shows the same
The servo is new 1.8kw I believe 10000 count connected to 7i76 with differential step/dir when the servo is stationary and I try to move it. It returns back to position. So I assume that is correct.
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
- Thank you received: 5972
11 Jan 2020 22:40 #154647
Replied by tommylight on topic Closing the servo loop with HAL mesa 7i76
That is just a warning, it can be removed by lowering the max_velocity in the ini file for the X axis.I am getting an error " hm2/hms_5i25.0: stepgen.00.maxvel is too big for current step timings & position-scale, clipping to max possible
11 Jan 2020 22:49 - 11 Jan 2020 22:51 #154650
from the X axis section of your ini file:
MAX_VELOCITY = 250
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 2000
With a max velocity of 250 mm/s and a step scale of 2000 steps/mm you are right at the
limit of the stepgens maximum rate at the current steplen and stepspace settings:
Maximum step rate = 1/(steplen+stepspace) so 500 Khz at your current settings
500 KHz is also stepscale * maxvel = 2000*250 = 500 KHz.
If you need higher velocities you will need to shorten the steplen and stepspace.
MAX_VELOCITY = 250
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 2000
Last edit: 11 Jan 2020 22:51 by PCW.
11 Jan 2020 23:31 #154654
by Clive S
Thanks Tom have you checked your email or changed it?
Time to create page: 0.167 seconds
