Want to run C2000 Delta with Ethercat card
28 Feb 2020 03:38 #158723
by snujcnc
Want to run C2000 Delta with Ethercat card was created by snujcnc
Hi
if anyone run Delta C2000 With ethercat card please share me driver file for ethercat
when i try to connect ethecat delta drive c2000 (VFD) it show Ec-time out error
07 Mar 2020 03:54 - 07 Mar 2020 12:22 #159369
by snujcnc
Replied by snujcnc on topic Want to run C2000 Delta with Ethercat card
Just get delta vfd c2000 with Ethercat option card in to operation state
But still in very primary stage working on full driver
(Busy in other project)
Update once finish
Update once finish
Last edit: 07 Mar 2020 12:22 by snujcnc.
The following user(s) said Thank You: taloot
08 Mar 2020 03:47 #159454
by snujcnc
c2000 in op state but no communication
ethercat slaves -v shows
=== Master 0, Slave 0 ===
Device: Main
State: OP
Flag: +
Identity:
Vendor Id: 0x000001dd
Product code: 0x10400140
Revision number: 0x00010000
Serial number: 0x00000000
DL information:
FMMU bit operation: no
Distributed clocks: yes, 64 bit
DC system time transmission delay: 0 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0 MII up open yes - 1127557155 0 0
1 MII down closed no - - - -
2 N/A down closed no - - - -
3 N/A down closed no - - - -
Mailboxes:
Bootstrap RX: 0x0000/0, TX: 0x0000/0
Standard RX: 0x1000/128, TX: 0x10c0/128
Supported protocols: CoE
General:
Group: Drives
Image name: DRIVE
Order number: C2000(CMC-EC01 Card)
Device name: Delta C2000 EtherCAT(CoE)
CoE details:
Enable SDO: yes
Enable SDO Info: no
Enable PDO Assign: no
Enable PDO Configuration: no
Enable Upload at startup: no
Enable SDO complete access: no
Flags:
Enable SafeOp: no
Enable notLRW: no
Current consumption: 0 mA
any suggestion ?
Device: Main
State: OP
Flag: +
Identity:
DL information:
Mailboxes:
General:
Group: Drives
Image name: DRIVE
CoE details:
Enable SDO: yes
Enable SDO Info: no
Flags:
Enable SafeOp: no
Enable notLRW: no
any suggestion ?
12 Mar 2020 06:06 #159844
by chimeno
Replied by chimeno on topic Want to run C2000 Delta with Ethercat card
Hi @snujcnc
I don't know what you need, but it still helps you,
you can use the commandto see the PDOs and then use linuxcnc-ethercat with the "generic" controller,
ethercat pdos -p0
The following user(s) said Thank You: snujcnc
12 Mar 2020 11:09 #159862
by snujcnc
can you provide me working example for any of bellow ethercat slaves
1-delta servo asda
2-estun servo
3-yaskawa servo,
4-invt servo
or any other servo which works with generic controller
thanks
1-delta servo asda
2-estun servo
3-yaskawa servo,
4-invt servo
thanks
12 Mar 2020 20:14 #159921
by chimeno
Hello @snujcnc,
here's a forum while using the generic controller. forum.linuxcnc.org/27-driver-boards/3559...-to-install?start=70
Best regards
Chimeno
Best regards
Chimeno
02 Dec 2020 18:43 - 02 Dec 2020 18:44 #190895
by Mduran
Replied by Mduran on topic Want to run C2000 Delta with Ethercat card
Hi @snujcnc,
did you manage to get delta to work with ethercat card?
Last edit: 02 Dec 2020 18:44 by Mduran.
02 Dec 2020 20:48 #190904
by chimeno
Hello @Mike Duran
If you have the physical device I can try to help you.
Greeting
Chimeno
Greeting
Chimeno
19 Dec 2020 14:47 #192456
by snujcnc
Sorry for late reply ....
i have phisycal device with me ....
please tell me next step ....
19 Dec 2020 14:49 #192457
by snujcnc
not yet
