Want to run C2000 Delta with Ethercat card
19 Dec 2020 16:59 - 19 Dec 2020 17:18 #192465
by chimeno
Replied by chimeno on topic Want to run C2000 Delta with Ethercat card
Hello @snujcnc,
Have TWINCAT3 to configure and test it to work??
Do you have a manual??
You have linuxcnc-ethercat installed??
you can scan the device with the commandto get that the PDO starts with the device, then it would try to create the ethercat .xml configuration file with the generic mode
Greeting
Chimeno
sudo ethercat pdos
Greeting
Chimeno
Last edit: 19 Dec 2020 17:18 by chimeno. Reason: Edit
- diegojulio
28 Feb 2023 18:58 #265595
by diegojulio
Replied by diegojulio on topic Want to run C2000 Delta with Ethercat card
Hello Chimeno, I want to know if you can help me to configure the generic XML file for Delta C2000 plus VFD with ethercat card CMC-EC01?
I can see the drive with ethercat slaves, but when I run the ethercat slaves pdos, the slave does not appear. Thanks in advance
- diegojulio
28 Feb 2023 19:01 #265597
by diegojulio
Hello: did you had success with the control of C2000 VFD with ethercat card CMM-EC01?
Time to create page: 0.073 seconds
