MPG - HAL Question(s)
08 Mar 2020 20:13 #159505
by mooser
MPG - HAL Question(s) was created by mooser
Wired an offshore pendant (xyz456 type with an enabled button and e-stop) into my 7i76 lathe using various samples I found on the net
Modified a sample Custom.HAL using the linuxcnc document and I almost have something working
Currently:
Estop button is working (although I had to disable the other e-stop but that's a different problem)
The enable button is working
the Axis select X and Z are working (axis-select-x and z in the hal meter)
The scale (x1 x10 x100) is working (scale 1 or scale 2 = true and mpg shows .001, .01 and .1)
Trying to get the handwheel working now, i've got the power connected to TB3 #20 and gnd to #24 so taking 5v from the 5i25, A/A- and B/B- to pins 16 through 19 on TB5
In the custom.HAL I've entered
loadrt encoder num_chan=1
loadrt mux4 count=1
#addf encoder.capture-position servo-thread # not sure what this is
#addf encoder.update-counters base-thread # not sure what this is
addf mux4.0 servo-thread
# If your MPG outputs a quadrature signal per click set x4 to 1
# If your MPG puts out 1 pulse per click set x4 to 0
setp encoder.0.x4-mode 1
net mpg-a encoder.0.phase-A <= hm2_5i25.0.7i76.0.0.input-18
net mpg-b encoder.0.phase-B <= hm2_5i25.0.7i76.0.0.input-19
but what would the other part of the quad (A- and B-) be? is it as simple as
net mpg-a encoder.0.phase-A- <= hm2_5i25.0.7i76.0.0.input-16
net mpg-b encoder.0.phase-B- <= hm2_5i25.0.7i76.0.0.input-17
Also, what would the signal be to watch on the hal meter? X-jog-counter?
M
Currently:
loadrt mux4 count=1
M
The following user(s) said Thank You: Bncs
08 Mar 2020 20:26 - 08 Mar 2020 22:08 #159507
Replied by PCW on topic MPG - HAL Question(s)
You don't need a software encoder component nor do you need to deal with the
digital inputs pins, instead you use the 7I76s mpg encoder pins:
hm2_5i25.0.7i76.0.0.enc0.count
and
hm2_5i25.0.7i76.0.0.enc1.count
and connect them to motions jog input pins
and
Last edit: 08 Mar 2020 22:08 by PCW. Reason: wrong card
08 Mar 2020 21:00 - 08 Mar 2020 21:16 #159509
by mooser
Replied by mooser on topic MPG - HAL Question(s)
Just when I thought I was doing well I'm not sure about the...
"software encoder component nor do you need to deal with the digital inputs pins," can you clarify a bit for me?
Here's what I've got right now
# Include your custom HAL commands here
# This file will not be overwritten when you run PNCconf again
# Jog Pendant
loadrt mux4 count=1
loadrt and2 count=1
addf and2.0 servo-thread
# For position mode (the default), set to 0
# In position mode the axis will move exactly jog-scale
# units for each count, regardless of how long that might take,
setp axis.0.jog-vel-mode 0
setp axis.2.jog-vel-mode 0
# This sets the scale that will be used based on the input to the mux4
setp mux4.0.in0 0.001
setp mux4.0.in1 0.01
setp mux4.0.in2 0.1
# The inputs to the mux4 component
net scale1 mux4.0.sel0 <= hm2_5i25.0.7i76.0.0.input-25 #27
net scale2 mux4.0.sel1 <= hm2_5i25.0.7i76.0.0.input-26 #28
# The output from the mux4 is sent to each axis jog scale
net mpg-scale <= mux4.0.out
net mpg-scale => axis.0.jog-scale
net mpg-scale => axis.2.jog-scale
# The MPG inputs
#net mpg-a encoder.0.phase-A- <= hm2_5i25.0.7i76.0.0.input-16
#net mpg-b encoder.0.phase-B- <= hm2_5i25.0.7i76.0.0.input-17
# The Axis select inputs
net axis-select-x <= hm2_5i25.0.7i76.0.0.input-20
net axis-select-z <= hm2_5i25.0.7i76.0.0.input-22
# --- ESTOP-EXT ---
net estop_jog <= hm2_5i25.0.7i76.0.0.input-00
# --- MAPPING MPG ENCODER signals to jog counters I believe this is the connection you mean?
# using two different encoders for different axis (X,Z)
net x-jog-counter <= hm2_5i25.0.7i76.0.0.enc0.count
net z-jog-counter <= hm2_5i25.0.7i76.0.0.enc1.count
# --- MAPPING INPUT signals and modes to linux cnc signals / gui
net x-jog-counter => axis.0.jog-counts
net z-jog-counter => axis.2.jog-counts
# Transfer input signal to linux cnc action (enable axis selection)
net axis-select-x => axis.0.jog-enable
net axis-select-z => axis.2.jog-enable
# ESTOP button trigger GUI control
net estop_prog <= iocontrol.0.user-enable-out
net estop_prog => and2.0.in0
net estop_jog => and2.0.in1
net and2out <= and2.0.out => iocontrol.0.emc-enable-in
#net temp <= passthrough.in
Now since I don't see any call for the actual input pins (I'm on TB5, pins 1234, input 16-17-18-19 now) I can only guess there are a specific set on the 7i76 I should be using instead? OK so there it is where it explained the mode 2, I just missed it, so I'm on the correct pins (I think) except it's for two encoders do I just leave the A- and B- unconnected?
M
# Jog Pendant
loadrt mux4 count=1
loadrt and2 count=1
setp mux4.0.in2 0.1
# The MPG inputs
# --- ESTOP-EXT ---
M
Last edit: 08 Mar 2020 21:16 by mooser. Reason: found the Mode 2 MPG pin reference
08 Mar 2020 21:20 #159512
Yes leave the - pins of differential encoder outputs unconnected
Plus all this stuff can be deleted:
# The MPG inputs
# The MPG inputs
08 Mar 2020 21:29 #159514
by mooser
Thanks, doing it now
When I add the
it gives me an error on load
I've got to check the main HAL again to make sure I'm in Mode2, I thought I was but maybe not
Does that (hm2_5i25.0.7i76.0.0.enc0.count) have to be called in the main rather than this custom or anything?
M
When I add the
M
08 Mar 2020 21:46 #159516
Yeah, it sounds like the mode is not correct
The hal pin is available after the driver is loaded so it make no difference
where the net connection is made as long as its done after the hardware
drivers are loaded
drivers are loaded
08 Mar 2020 21:58 - 08 Mar 2020 22:01 #159517
by mooser
Custom HAL now has....
hm2_7i76e.0.7i76.0.0.enc1.count
# Jog Pendant
loadrt mux4 count=1
loadrt and2 count=1
From the main HAL
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=1 num_pwmgens=0 num_stepgens=2 sserial_port_0=20xxxx"
Originally all I changed was the 0=00xxxx to 0=20xxxx, did I miss something
M
# Jog Pendant
loadrt mux4 count=1
loadrt and2 count=1
From the main HAL
loadrt trivkins
loadrt hostmot2
M
Last edit: 08 Mar 2020 22:01 by mooser.
08 Mar 2020 22:09 #159519
Sorry my example up above had the wrong card
hm2_7i76e.0.7i76.0.0.enc1.count needs to be
08 Mar 2020 22:16 #159521
by mooser
No you had it right I just typed it wrong on here
is what is in the custom.hal
Still errors on launch saying it doesn't know that command
Main hal has
but it can't be going into mode 2. Is there any other setting?
M
Main hal has
M
08 Mar 2020 22:22 - 08 Mar 2020 22:38 #159522
Yeah that's correct
You can't have a pin name as the first token in a hal file
it has to be
net some_signal_name some_pin_name
or
net some_signal_name some_pin_name some_other_pin_name yet_another_pin_name
etc
Or in this specific instance:
it has to be
or
etc
Last edit: 08 Mar 2020 22:38 by PCW.
Time to create page: 0.173 seconds
