MPG - HAL Question(s)
30 Aug 2020 22:24 #180114
by nf1z
Replied by nf1z on topic MPG - HAL Question(s)
Peter,
Thanks, that did it. I am already at R15, luckily. I was guessing from the name that it might be that parameter, but no clue on the range of values. In the interests of saving your time answering similar questions, is that kind of thing documented anywhere? I have used LinuxCNC for many years, in fact when it was still EMC, but have managed to avoid getting into the gory details for the most part, and had no previous need to delve into the Mesa-specific stuff. I like the 7i76e a lot so far, but it is requiring a bit of thought to make full use of it.
Just in case it is useful, let me record that I also had to make a couple of other changes to the pncconf .hal file. I had to change (e.g.)
net selected-jog-incr => axis.x.jog-scale
net axis-select-x => axis.x.jog-enable
net axis-selected-count => axis.x.jog-counts
to:
net selected-jog-incr => joint.0.jog-scale axis.x.jog-scale
net joint-select-a => joint.0.jog-enable axis.x.jog-enable
net joint-selected-count => joint.0.jog-counts axis.x.jog-counts
I did find that on the web, but it seems a little odd that pncconf generated net statements for joint-select-a (etc.) and then used axis-select-x instead.
to:
30 Aug 2020 23:08 - 30 Aug 2020 23:14 #180118
Replied by PCW on topic MPG - HAL Question(s)
It would probably be a good option if pncconf had a checkbox to allow for jog before homing
(what you have implemented by connecting to motions joint and axis jog pins )
Its not desirable in many cases
The 7I76 mpg encoder quadrature modes are:
0 1x forward
1 1x reverse
2 2x forward
3 2x reverse
4 4x forward
5 4x reverse
0 1x forward
1 1x reverse
2 2x forward
3 2x reverse
4 4x forward
5 4x reverse
Last edit: 30 Aug 2020 23:14 by PCW.
31 Aug 2020 14:39 #180170
by nf1z
Peter,
Thanks for the info.
I'm new to all this joint/axis stuff. I see the point about jogging before homing, though as a repairer of CNC machines, I can't imagine working on a machine I couldn't manually move at any time, one way or another. Still, probably a good option. Actually, my point was (or should have been) that the pncconf .hal file could not allow MPG jogging at all, because there is no option that I could find in the pull-downs for a signal (?) called axis-select-x, just joint-select-A, though it generates the net statement:
I do like the pncconf options to set things like backlash that are not there in stepconf. Remembering to modify the .ini file was always a pain, so the more stuff in the wizard the better.
01 Sep 2020 09:37 #180283
That statement has no affect, it is just creating a signal you can use if you wish to connect it to another pin.
Replied by rodw on topic MPG - HAL Question(s)
Time to create page: 0.157 seconds
