[ Vfdmod ] An easy VFD control over MODBUS RTU
11 Mar 2021 20:58 #201860
by Zbysob1
Replied by Zbysob1 on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
ok one step more
it's look like :
Opening /dev/ttyUSB0 at 9600 bauds (N, 8, 1)
vfdmod: reading 'spindle.rpm-out' from address 8203 (0x200B)...
[01][03][20][0B][00][01][FE][08]
Waiting for a confirmation...
<00>
vfdmod: setting command speed value to 5 (0x0005)...
[01][06][20][01][00][05][13][C9]
<00>
<00>
<00>
and so on ...
but the minimum speed is correctly written to the inverter - it changes from zero to 5
it's look like :
<00>
<00>
<00>
<00>
and so on ...
12 Mar 2021 01:13 #201917
by aekhv
Replied by aekhv on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
Try to increase ProtocolDelay to 5...15 and watch to debug, is something changes?
12 Mar 2021 05:35 #201927
by Zbysob1
After increasing ProtocolDelay, ignored replies from random senders show "The responding slave 127 isn't the requested slave 1 , ...,
The responding slave 217 isn't the requested slave 1 "and after several such replies return to " ERROR Connection timed out: select. " Only the read request 8203 and write 8193 is sent. The minimum frequency is correct.
12 Mar 2021 05:49 #201928
by Zbysob1
I changed the converter to yours and now the debug out looks correct - next commands and the inverter answer, but the running program still shows connection errors and you can not control the direction or rotation
12 Mar 2021 05:53 #201929
by Zbysob1
Error code for RS485 is 112345679 and diode is RED
12 Mar 2021 06:12 #201930
by aekhv
No returned value after this block, it seems like my read coils function works wrong. Try to delete "user-coil-parameter" parameter from your ini.
vfdmod: reading 'parameters.user-coil-parameter' from address 8193 (0x2001)...
[01][01][20][01][00][01][A7][CA]
<01><81><01><81><90>
12 Mar 2021 06:26 #201931
by Zbysob1
You are genius
I deleted this fragment and made my-pyvcp-panel.xml file and postgui.hal file again. The connection is green and no errors
I'll check the rest in the evening because work is waiting. Thanks again Aekhv
13 Mar 2021 06:42 #202060
by Zbysob1
Communication is ok but no reaction to traffic commands. The "Spindle at speed" diode is red and there is no reaction to start and stop and RPM setting. Information about the minimum revolutions is sent to the inverter, but only the revolutions without a movement command - the display on the inverter blinks with value of minimum
13 Mar 2021 06:57 #202063
by aekhv
Well, possible reasons are:
a) wrong control register address and / or wrong control world values. See your device manual to be sure.
b) wrong HAL connections. Show your HAL files please, I'll try to help.
13 Mar 2021 07:57 #202068
by Zbysob1
I think the registers are ok - sending the value 0x0012 to the address 0x2000 causes the start to the right, etc.
Time to create page: 0.137 seconds
