6i25 7i76 closed loop spindle
15 May 2020 13:28 #167840
Replied by PCW on topic 6i25 7i76 closed loop spindle
encoder scale should be 8000
- Online
- Thank you received: 5997
15 May 2020 14:18 #167846
Replied by tommylight on topic 6i25 7i76 closed loop spindle
Max rpm of motor/encoder=4,000rpm and spindle=8000.
15 May 2020 15:10 #167852
by Bob654321
Replied by Bob654321 on topic 6i25 7i76 closed loop spindle
If i look at hm2_5i25.0.encoder.00.count in hal meter and spin the spindle 1 revolution i get 2000.
- Online
15 May 2020 15:17 #167854
Yup and the setting in ini was correct. The thing that threw PCW off was you always write 2:1, it should be 1:2 or one rev of motor 2 revs on the spindle.If i look at hm2_5i25.0.encoder.00.count in hal meter and spin the spindle 1 revolution i get 2000.
15 May 2020 15:29 #167857
by Bob654321
I am sorry for the confusion I have caused. Thanks for clearing that up.
15 May 2020 16:01 - 15 May 2020 16:02 #167860
Yes I was confused by the 1:2 2:1 thing
Still not sure whats going on
can you run the spindle open loop (only FF0=1) and halshow these values when
running at say 1/2 full speed (4000 RPM)
pid.s.command
pid.s.feedback
pid.s.output
pid.s.command
pid.s.feedback
pid.s.output
Last edit: 15 May 2020 16:02 by PCW.
15 May 2020 16:12 #167862
by Bob654321
for m3s4000
pid.s.command=4000
pid.s.feedback=0
pid.s.output=4000
pid.s.command=4000
pid.s.feedback=0
pid.s.output=4000
15 May 2020 16:17 - 15 May 2020 16:22 #167863
OK well that would explain the crazy behavior
next step would be to find out where the feedback speed gets lost
Ahh mis-matched signal names:
net spindle-fb-rpm-abs abs.spindle.out => lowpass.spindle.in
net spindle-vel-fb-rpm-abs => pid.s.feedback
Last edit: 15 May 2020 16:22 by PCW. Reason: add error
15 May 2020 16:51 #167875
by Bob654321
How should I fix this? Being the newbie I am its not obvious to me what should be replaced, deleted, or added to my hal file.
15 May 2020 16:53 #167877
replace
with
net spindle-fb-rpm-abs => pid.s.feedback
with
Time to create page: 0.466 seconds
