During start i get this error USRMOT: ERROR: command timeout
26 May 2020 23:13 #169015
by Korbi
Hi
i try to build my first NC with LinuxCNC
i want to start with some real basic configs.
but when i try to start my machine i get this log:
Machine configuration file is 'Test_Maschine.ini'
Starting LinuxCNC...
Found file(REL): ./Test_Maschine.hal
Note: Using POSIX realtime
emcMotionInit: emcTrajInit failed
Config is is in attachments
can someone help me to start LinuxCNC
The following user(s) said Thank You: bbsr_5a
27 May 2020 07:56 #169060
by bbsr_5a
Replied by bbsr_5a on topic During start i get this error USRMOT: ERROR: command timeout
Welcome
did you firer up a simulation machine First
its a simple XYZ setup
so why did you choose to go for 2.9 insted of just doing the Debian Stretch iso with 2.7.15 on it
- Thank you received: 5983
27 May 2020 08:03 #169061
Replied by tommylight on topic During start i get this error USRMOT: ERROR: command timeout
Test machine hal file is empty.
27 May 2020 08:50 #169067
by Korbi
Replied by Korbi on topic During start i get this error USRMOT: ERROR: command timeout
i am able to start sim machines, like the axis_mm and so on.
I followed a tutorial and get Linuxcnc 2.9.
When nessesarry i can switch to 2.7
You say:
Testmachine hal is empty, what should be inside for a test start?
You say:
27 May 2020 10:18 #169104
Attached is one of my hal files.
01 Jun 2020 20:28 #169710
by Korbi
ThankĀ“s very mutch,
now LinuxCNC is starting.
But i fail into the next problem.
I can not reset the e-stop and turn "on" the Machine.
01 Jun 2020 20:45 #169711
The pin the the e-stop is attached to in hal has to be inverted, something like:
net FloatSwitch parport.0.pin-13-in
to
net FloatSwitch parport.0.pin-13-in-not
or vice versa, notice the added -not at the end off the line.
to
03 Jun 2020 09:03 #169926
by Korbi
Thank you.
actual my Problems are solved
Time to create page: 0.211 seconds
