2 pole 6 Position rotary switch for (2x) MPG enable and scale settings
- Mike_Eitel
- Thank you received: 185
30 May 2020 20:26 #169452
by Mike_Eitel
Replied by Mike_Eitel on topic 2 pole 6 Position rotary switch for (2x) MPG enable and scale settings
Are you aware that you can restrict these switches to les positions by seting a pin in the wholes on the front.
31 May 2020 10:38 #169504
by denhen89
Replied by denhen89 on topic 2 pole 6 Position rotary switch for (2x) MPG enable and scale settings
Thanks Mike for that Information. As soon as I will be back home I will test it. I just checked the picture from the aliexpress product page and I see 2 holes on the front. I will let you know when if it's possible to restrict the switch to 4 positions
- Mike_Eitel
31 May 2020 10:40 #169505
by Mike_Eitel
They are near to the axle.. Under the metal washer ;-()
31 May 2020 11:37 #169507
by denhen89
Good to know, thanks!
31 May 2020 14:57 #169522
by denhen89
Mike you were right. Under the metal washer is a ring which can be turned to i think 12 positions
Thanks for that!
Thanks for that!
- Mike_Eitel
31 May 2020 19:40 #169558
by Mike_Eitel
Pleasure.. I'm happy for you.
Mike
Mike
The following user(s) said Thank You: denhen89
19 Oct 2020 21:34 #186627
by fons
Replied by fons on topic 2 pole 6 Position rotary switch for (2x) MPG enable and scale settings
hallo denhen
did the witch work fine ?
i'm trying to set up one mpg for multiple axis controlet with a switch with mesa 7i76e
i don't know how to start there is an example in the documentation but with pareport
how doid you do it ?
Time to create page: 0.176 seconds
