Problem with HAL with 2 OUT pins
14 Oct 2020 11:55 #186089
by Clive S
Problem with HAL with 2 OUT pins was created by Clive S
This is from forum.linuxcnc.org/38-general-linuxcnc-q...etup?start=30#185996
net apos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net apos-cmd toolchanger.position-cmd => stepgen.2.position-cmd
The error is signal apos-cmd cannot add OUT pin "toolchanger.position-cmd" it already has OUT pin "stepgen.2.position-cmd "
So how do I solve this
14 Oct 2020 14:20 #186093
Replied by PCW on topic Problem with HAL with 2 OUT pins
Usually a mux component that selects which output signal should drive the input
is used. Note that switching modes may be fairly complex to avoid motion discontinuities
loadrt mux2
addf mux2.0 servo-thread
net apos-cmd-motion <= joint.2.motor-pos-cmd => mux2.0.in0
net apos-cmd-toolchanger <= toolchanger.position-cmd => mux2.0.in1
net apos-cmd <= mux2.0.out => stepgen.2.position-cmd
net apos-mode <= toolchanger-active mux2.0.sel
loadrt mux2
14 Oct 2020 15:17 - 14 Oct 2020 15:26 #186100
by Clive S
Replied by Clive S on topic Problem with HAL with 2 OUT pins
Thanks Peter
I get an error toolchanger-active does not exist. I don't see any pins by that name
With this;-
loadrt toolchanger
addf toolchanger servo-thread
loadrt mux2
net tool-change iocontrol.0.tool-change => toolchanger.toolchange
net tool-changed iocontrol.0.tool-changed <= toolchanger.toolchanged
net tool-number iocontrol.0.tool-prep-number => toolchanger.toolnumber
net tool-oldnumber iocontrol.0.tool-number => toolchanger.currenttoolnumber
##net apos-cmd toolchanger.position-cmd => stepgen.2.position-cmd
net ahomed joint.2.homed => toolchanger.ishomed
net estop-ext => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
#net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
With this;-
loadrt toolchanger
loadrt mux2
Last edit: 14 Oct 2020 15:26 by Clive S.
14 Oct 2020 15:31 #186101
I just made up that name.
You would need a signal that indicates the the toolchanger is active and
expects to control joint2
Note that I am not suggesting this as a solution to anything but the issue
of driving a hal input (the stepgen position in this case) from two different
sources (the toolchanger position in one case and the joint 2 position in the other)
Expect wild motions and following errors even after you determine what should select
the stepgen source
the stepgen source
Time to create page: 0.216 seconds
