XHC-WHB04B-6 Help needed
11 Jan 2021 22:48 #194974 by ChrissyAG
Replied by ChrissyAG on topic XHC-WHB04B-6 Help needed
I've quickly commented (hashed) out all lines under this section of Matilda001.hal.
Unfortunatley, the behavior is still the same.
Not sure what to do next.
11 Jan 2021 22:50 #194975 by alkabal
Replied by alkabal on topic XHC-WHB04B-6 Help needed
have you skype ?
team viewer ?
11 Jan 2021 22:51 - 11 Jan 2021 22:52 #194976 by alkabal
Did you use a buildbot instal or a run in place ?
All the error i see in your picture is signal already linked so you need to found solution for unconnect this signal from other place
Last edit: 11 Jan 2021 22:52 by alkabal.
11 Jan 2021 22:55 #194977 by ChrissyAG
sorry, I only saw half of your reply when I hit send on my previous reply.
I will now check the pendant file and reset it to it's original state and follow your additional suggestions and report back when I have run it again.
I don't have skype but I could set it up if that is easier. (I would need to get a webcam).
11 Jan 2021 23:01 - 11 Jan 2021 23:02 #194981 by alkabal
Did you use a buildbot install or a run in place ?
If you use run in place (compiling linuxcnc yourself) a file need a copy past in rules folders ! (no need if you install from apt-get)
sudo cp /home/pi/emc/debian/extras/lib/udev/rules.d/*.* /etc/udev/rules.d
Last edit: 11 Jan 2021 23:02 by alkabal.
The following user(s) said Thank You: vre
11 Jan 2021 23:36 #194986 by ChrissyAG
SUCCESS!!!!!!!!
I went back to the pendant file ie the one I posted most recently and then simply changed:
#net machine.is-on halui.machine.is-on whb.halui.machine.is-on
to:
saved the file and started LinuxCNC to check and WOOOHOOO! I have encoder counts!
I cannot thank you enough, this has been a very steep learning curve so far, but the pendant was the thing that really tripped me up.
I'm sure this is not the last issue I will have with configuring LinuxCNC on my machine, but at least I feel confident to go forwards and get the rest of it sorted. Especially knowing that the expertise is only a message away.
Thank you so much. You have literally saved my project.
03 Oct 2021 08:18 - 03 Oct 2021 08:19 #222077 by jurod
Replied by jurod on topic XHC-WHB04B-6 Help needed
Hi, is it possible to somehow change the sense of turning the wheel when jogging?
Example:
select axis A =>
wheel rotate to +
but i need axis A rotate to -
Last edit: 03 Oct 2021 08:19 by jurod.
04 Oct 2021 21:18 - 04 Oct 2021 21:20 #222221 by alkabal
Hi
Maybee using this component :
github.com/robEllenberg/linuxcnc-mirror/...mponents/invert.comp
loadrt invert    names=invert.a
addf invert.a    servo-thread
net pdnt-axis.A.jog-counts    whb.axis.a.jog-counts    invert.a.in
net pdnt-axis.A.jog-counts-inverted     invert.a.out     axis.a.jog-counts
totaly untested
Br
Last edit: 04 Oct 2021 21:20 by alkabal.
05 Oct 2021 10:05 #222265 by jurod
Error. The jog-counts is type s32 and component Invert is type float.
The following example works, but with a feature:
net pdnt-axis.A.jog-counts    whb.axis.a.jog-scale    invert.a.in
net pdnt-axis.A.jog-counts-inverted     invert.a.out     axis.a.jog-scale
Selective incremental wheel
0.001 => 5
0.01 => 1
0.1 => 0.1
1 => 0.01
5 => 0.001
09 Nov 2021 14:45 #225833 by roland206
Replied by roland206 on topic XHC-WHB04B-6 Help needed
I just read your chat regarding your XHC-WHB issue. You solved the problem and wrote "SUCCESS!!!!!!!!". I don't undestand what you changed. I have the same (or similar) problem and don't know how to solve it.
Time to create page: 0.143 seconds
